Question about ViewSonic VP201b 20.1" LCD Monitor
No display, green light on ViewSonic VP201b 20.1 LCD
Turn monitor on but no display. Screen is black, no backlighting. Green light is on. What could the problem be?
  • 2 more comments
  • Anonymous May 11, 2008
    ive got the same problem. its powered up, but the screen is black, no display.
  • 84CJ Sep 11, 2008
    Power on, green led lit, but screen black.
    Tried disconnecting the cable and reconnecting. Vista recognised that the hardware had been removed and reconnected by giving it's little noise, but screen still black.
  • Anonymous Nov 15, 2008
    Suddenly goes black, but green light is still on. Comp still thinks it's ok, but the screen is black
  • Anonymous Mar 27, 2014
    Monitor has gone black, stuck on Power Save mode light
I have two broken VP201 monitors with different symptoms. One was black screen green light - like yours. The other was purple speks flying all over the screen., purple tint.
I swapped the power supplies and display boards, both monitors had original problems. I swap the inverters and the monitor which was black screen now appeared to work okay - but slightly pink and the monitor which was purple speks is now black screen.
I would therefore assume that both my inverters gone, one being on it's way out. You probably have the black-screen case.
Posted on Aug 27, 2008
Probably burned out power supply
Posted on Jun 03, 2008
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
Check the fuse on the inverter board F1.
No display, green light on ViewSonic VP201b 20.1 L - ade7bd7f-10ed-4a85-b714-5b234f87a78b.jpg
Posted on Apr 19, 2013
Hi, I have a ViewSonic VP201b monitor that has a problem.... It seems that it wont turn on (BLACK SCREEN *NOTHING*). The yellow light goes on when idle, but when it's not idle the green light isn't...
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
May 12, 2017 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Viewsonic va1912w monitor no display cables ok computor ok green light flashes
this might be the problem of backlight which is used to give away light for viewing of color watch carefully u might see the picture without color if it is though then change the backlight byy contacting ur nearest service center
Jul 04, 2010 | ViewSonic VA1912w 19" LCD Monitor
Vp201b wont turn on
Checkto see if you do have 12vdc output from the power supply module as shown in my pictures: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VP201B/
Look for bad caps (leaking/bulging tops).
May 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
2,920 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
