Question about Fisher and Paykel Dishwashers
My Fisher Paykel dw60cdw2 dishwasher stopped working mid cycle and I cant get it started again even aftre switching power off and pressing reset.. All lights on the console are working except the number display on the left side. What is the problem likely to be
Had the same problem and it was the microswitch that is behind the door skin which is associated with the lock mechanism. got a new one and away she went
Posted on Jan 15, 2011
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher pumps even with power off
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Mar 28, 2010 | Viking 24 in. Professional Series VUD040...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
hold all three bottons: power, pause and start and power cycle the unit, it will reset the dish washer.
Nov 22, 2008 | Fisher and Paykel DD605SS Stainless Steel...
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
603 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
