Question about MTX Thunder 4250D Car Audio Amplifier
What kind of amp should i get for my kenwood mids and highs
  • 70 Answers
You should go for a 4 channel amp that has 500 watts and try to go for MTX
Posted on Aug 04, 2010
Testimonial: "was really good"
I have a Kenwood DNX8120 installed in a Jeep Wrangler(4dr). Running a 4 channel JL Audio amp for mids and highs and mono JL audio amp for the single 12" sub. Tried to have the deck tuned by two...
I do not know what sub woofer and speakers you have and how they are installed, don't change the JL Audio amplifiers, they are very good amplifiers. Also amongst others, I have been using Kenwood in my installs for many years and believe them to be one of the top brands for head units. The unit that you have is a good, very good unit, honestly. In a nut shell, the equipment that you mention are all top class and if functioning correctly, should not be the cause of your disappointment. Low quality cables, bad installations or even incorrect tuning, are often the guilty party in cases such as these. You could fill me in on what else you have and what kind of box the sub woofer is in and what car they are installed in? Search for the source of your disappointment somewhere else. dreamsystems.
Feb 22, 2011 | Kenwood Car Audio & Video
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Blown fuses
I agree with the last answer- your amp has built in fuses that should be rated at 30 amperes each which should be sufficient as the amp only pulls 60 amperes at full power-however you may want to upgrade your power /ground wires to a good 4 gauge set if you dont already have it set up like that-throw an 80-100 amp fuse up front by the battery in case your running another amp for mids and highs just to cover the current draw of the amps combined. If the amp is still blowing fuses after that check to make sure that your subs are wired to no lower than a 2 ohm load as the amp is only stable to 2 ohms.
May 11, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
MTX Thunder 4250D Car Audio Amplifier Logo
42 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
