Question about Compaq Presario 5000 PC Desktop
Usb ports not working after recover
I have a compaq pavillion and had to do a recovery...it took 4 times to take and still isn't acting right. anyway, my usb ports are not recognizing that my printer is connected. i tried to uninstall and reboot to no avail. what do i do?
  • heatherms75 Apr 26, 2008
    and here inlies the problem. the version I have is Media Center Edition which is basically a modified version of XP which only the computer manuf supports. They won't send me an installation cd b\c they want their techs to take control and do it so they can charge you. They won't even let you speak with a tech without charging you, even to just request the cd. I've had my rounds with them and it wasn't nice. I have a copy of XP Pro and I'm thinking I should just install it and call it a day unless anyone else has any suggestions.
    Genius:
  • 2,785 Answers
Dear heatherms75
your os is having problem plz reinstall it
Posted on Apr 26, 2008
Usb port hub does not recognize external hard drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Jul 05, 2012 | Rocketfish 4Port HiSpeed USB Hub
My Beyond Micr 250GB external HHD is not showing up on my PC running windows 7 and I have 2-1TB SATA HHD installed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover lost files.
http://www.asoftech.com/articles/External-Drive-Data-Recovery.html
Aug 28, 2011 | Beyond Micro 250 GB USB 20 Hard Drive
How fast can I recover saved data? I waited for long time and does not work.
you can recover saved data with asoftech data recovery software. You can refer to this tutorial
How to recover files with data recovery software
It uses unique modern algorithms to recover files that other software either recovers incorrectly or is unable to detect.
Jun 11, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
Hi, i was just wondering if i can't seem to find the usb icon when i plug in my external drive is there anyway i can still recover the files within the external hard drive. some poeple have told me...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 29, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My touchpad left click wont work but left click and when i move it it works . i even installed Synaptics - input -synaptics PS/2 Port TouchPad From windows update still the left click wont work...
I have this same problem on my pavillion dv6. sent it to warranty repairs twice they have replaced the keyboard, touch pad and mother board, worked about a week after last repair which took two weeks. I am sending it back on feb 10 for more replace parts and see if it works. I searched the web and I have not found any solution and hp won't even acknowledge the problem althoughit it is not limited to the hp product. Reconfigureing and downloading drivers etc. has done nothing but waste time. I am using usb mouse with touch pad disabled for now even that acts strange with the touch pad enabled.
Feb 05, 2011 | Compaq (153515-001) Touch Pad
Power light comes on but no accessories will work when plugged into USB ports
Steps:------
1.Plug in a different USB device in that USB port and check if it is working or not. If the 2nd device is working then the 1st USB device has gone bad. If none is working then try the steps mentioned below.
2.Unplug the powercable from the laptop and also unplug the battery. Press and hold the power button for 30-40 secs and then plug in the power cable and the battery and check.
3.click on START->right click on COMPUTER->click on MANAGE->click on DEVICE MANAGER->click on the symbol beside Universal Serial Bus Controller and uninstall all the USB ROOT HUB's and then restart the computer.
4.Run System Recovery from the Recovery Partion or Using the Recovery Disk.
Still if it remains then it is surely a hardware issue
Oct 19, 2010 | HEWLETT-PACKARD Compaq Presario CQ5302F...
Broken usb port
if you sure the usb ports are broken replace it..can replace that one. ethier second hand or new... if the device is available.......
Jun 09, 2009 | Computers & Internet
Hp pavillion usb ports
They are right, some DVs have this problem. If you can live without the ports, then do it. If you can't, replacement is the only option.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
My pc is not recognising my connected sandisk cruzer control stick?
Solution for ALL PCs with USB 2.0 ports.
1. Move it to the PRIMARY USB port.
2. Check your BIOS configuration to make sure your USB ports are enabled
3. Assign an IRQ to the USB ports ( this is done by Y/N setting in the BIOS )
4. Download and install service pack 2 ( usb 2.0 is enabled by installing service pack 2 )
Thank you for choosing FixYa!
Az. Wizard Division
Sep 23, 2008 | Computers & Internet
could be bad usb ports cheak bios are they enabled u could buy a pcmia card or docking stations with new ports cused by shock or gets hot fails
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5000 PC Desktop Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
