Question about Whirlpool Kitchen Ranges
Model rf365pxxn suddenly my range and oven stop heating, the surface lihts come on but nothing heats up.
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
  • 112 Answers
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 09, 2014 | Kenmore Kitchen Ranges
KitchenAid Electric Range Model KESA907PSS02 surface elements and oven all stopped producing heat after initially being 'on'
You might have blown the thermal fuse. Here is a diagram of your unit.
The fuse is number 37 on the diagram. Check it for continuity. Here is the part to order in case it is bad.
Keep me posted.
Regards,
Richard Roth
http://appliancecafe.com
For all your appliance repair needs.
Dec 09, 2012 | KitchenAid KESC308LSS Electric Kitchen...
My jenn-air electric range is about 18 years old. sometimes for no reason f1 and beeping occured but pushing cancel stopped it until next time.about 9 months ago when beeping wouldn't stop and touchpad...
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%$#E
Mar 04, 2010 | Jenn-Air JES9750AAS Electric Kitchen Range
Kgrc707 oven not working
it may hav over heated and caused the one time safty on back of oven to trip . replace safty and it should work . ps some times if it has a cooling fan the fan may have quit causing this problem . when the saftey failes look for the cause .. it will do it again . and the safty is about 30 .00 .. mm
Dec 24, 2009 | KitchenAid KGRC707 Stainless Steel Gas...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
My oven wont heat up.
can you tell me the model # off the stove. sounds like you may have to replacet the TOD or the heat probe.
Jun 24, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
87 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
