Question about Compaq Presario 5000 PC Desktop
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
  • raylee_csl Aug 05, 2010
    thanks for your reply. I should buy a IDE or SATA internal harddisk for SR5213?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Posted on Aug 04, 2010
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Maximum hard drive capacity for vgc-rc110g
caviar black 7200 rpm scorpio 1tb good hd.western digital.
Jun 05, 2012 | Sony VAIO RC110G (VGC-RC110G) PC Desktop
I put a new hard drive in and I am trying to load windows and it is not accepting it
First check out wheather the hard disk shows in bios setting or not ? If it shows then partition the harddrive properly and install windows.If it is not possible your harddisk has been damaged.
Aug 19, 2010 | Compaq Presario S6000CL (DT072A) PC...
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
I have a dimensions 5150 and want to add more disk space. What is largest size hard disk i can add and is there a thickness issue to bear in mind
technically there is no specific size limit ..currently the max. avaiable for home use is 1.5TB ...(LARGEST) hard drive
your model can surely fit in 500 gb of disk space...(again it all depends if u would be needs so much ) i leave that for u to decide .
assuming to dont have big video cards , that may cramp the internal space , i am sure anything under 500 gig should easily fit in ...
good luck
Oct 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Acer Hard disk D110 1 TB what should the transfer rate
Acer D110 External Harddisk 3.5" 1 TB
USB 1.1 / 2.0 compatible
480 Mbps max
USB powered
Oct 21, 2009 | Acer Computers & Internet
I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
I am usubg 845 gvrs motherboard now I want to installed extra internal harddisk what will be ideal harddisk and size
The size of the hard disk depends upon what type of programs you are running and the amount of data you need to store.
Programs that create large amount of data are audio and video files.
The tpye of hard drive depends on what type of disk controller you have, it could be IDE or SATA disk controller, you need to check your computer's hard disk controller.
The average hard disk capacity is 160 Gb to 180 Gb and goes up to 1 Tb, but the largest capacity drive your cmputer can support will depend upon the BIOS.
Jul 21, 2009 | Intel Computers & Internet
Compaq Presario 5000 PC Desktop Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
