Question about Samsung SyncMaster 740N 17" LCD Monitor
I have sumsung monitor 740N, problem disply time is 4 sec only,i check the pcv board all capacitor are ok.pls help to solve this.tnx
  • 11,361 Answers
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=740n&kategoria=&kat2=all
How is the DC voltage for the backlight inverter circuits?
Caps can look OK but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 04, 2010
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
Just monitor power on disply comes but after some seconds disply is gone
On Samsung 740 this is a very common problem with the high voltage impulse transformator in the invertor block. That needs to change.
May 16, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung's LCD monitor SyncMaster 740N; backlight failed, I replaced bulging capacitors on PSU and burnt fuse but backlight is still not coming on
There is a inverter transformer on the board that may be defective that generates the high voltage that drives the lamp, you may end up having to replace the whole inverter board to get it working again.
Jan 26, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
The lcd turned black, even though the power button is on
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
http://www.fixya.com/
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
D845GVFN disply problem
You check your VGA adapter, if it is buit in to main board, fixed cable connection, if it is add card remove and check the if is ok. if your remove then switch the board beeping twice faster beeps than the memory. Please response if this not solve the problem.
Jan 10, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Samsung SyncMaster 740N 17" LCD Monitor Logo
162 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
