I have a Philips 42" plasma TV model #42PF9631D/37. The tv would not turn on only red led light flashing 7 times. I replaced the capacitors as instructed in a blog on this site. When reconnected it still won't turn on and red led flashes 4 times. What can I try next?
  • Bruuhaa Aug 05, 2010
    Not much help. If I put a volt meter to the board it will tell me the same thing as the red led on the front of the tv. No power coming out of the board. Is there another capaitor I should be looking at or maybe a fuse problem?
  • 3,866 Answers
Just because the capcitors has blown does not mean just replacing them will fix the issue, if the capcitors blown and was really bad you going to need to go a step further and check the power supply fully meaning ic's, relay, High voltage transformer ect ect. its hard to tell what it is from email so I hope we have some understanding.
Posted on Aug 05, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 05, 2010
    I am sorry I was not much help to you, Seems liek the problem was not fixed when your replaced the defective cap's, If there are fuses on this board they would be thermal fuses there rectangle in shape and are usually blue you will need a voltage meter to see if the fuse is bad or not, you might have to end up replacing the whole board only time will tell. I would not suggest throwing parts at this guessing you be paying more then the cost of the tv doing so.
    Genrally I like to say this I am not there I cannot see the board effected nor can't I test over email I only can suggest where to take it form here so I hope you understand,
  • 11,896 Answers
I would test the power board. The power board is usually sold in one piece. Check the power going from the power board to the main board with a voltmeter. There should be a label on the tv with the DC voltage output
Posted on Aug 04, 2010
  • Henry  Thomas
    Henry Thomas Sep 28, 2011
    Your tv goes into a high voltage shutdown.which means that the high voltage has exceeded 33k and the unit goes immediately into saftey shut down check your power supply regulation.and your horizontal circuit.but with these kind of tv you will have to buy the power supply module and replace it with the old power supply.no use of doing any repair.
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Flashing red power light
probably some capacitors need to be replaced. i just replaced to in mine today and the tv works great.
Jan 25, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
