Question about Kicker CompVR 05CVR84 Car Subwoofer
How to wire Kicker CompVR 07CVR82 - Kicker CompVR 05CVR84 Car Subwoofer
  • dweinstein23 Nov 14, 2008
    i have a kicker vzx 300.1 amp and a kicker 10in comp vr subwoofer. How do i wire these together to get the maximum sound. thanks
  • 185 Answers
Theres many ways to wire it up let me no the specks on the amp
Posted on Oct 31, 2008
Will it hurt my 12"
I think you are asking about wiring you sub in parallel.
Positive on the sub to the other positive on the sub - then off to the + output of the amp
Negative on the sub to the other negative on the sub - then off to the negative of the amp
It will not hurt the sub, however you need to make sure that the amp you are using will be ok with the load you are presenting it.
Feb 04, 2011 | Kicker CompVR 05CVR84 Car Subwoofer
How to hook up two 10" kicker cvr for best sound
If they are single voice coil and are 4 ohm you can bridge your amp and run both speakers off of it so your amp sees a 2 ohm load....better bass that will hit harder....(series wiring) look it up on google....
Sep 25, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
Apr 25, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
How do you connect the kicker comp subwoofers
check this link out, it will give u all the options u need to correctly wire it up for your application.
http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html
Feb 18, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
How to wire 2 12 inch kicker cvr
depending on your amp, you can bridge by connectiung the speakers + to + and - to - and connect to amp using left + and right -, unless otherwise noted on amp. Please give a rating.
Nov 18, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Jan 15, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
Kicker compVR 12
get a ground loop isolator. and another set of rca's or just run the power wire on the other side of the car let me no if that helps please rate if help full or not
Sep 18, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Kicker CompVR 05CVR84 Car Subwoofer Logo
152 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
