Question about Sansui Audio Players & Recorders
Both channels of receiver have lost all bass. Loudness control has no effect whatsoever. All inputs affected and rest of receiver functions are ok.
  • Brad Brown Aug 04, 2010
    What is the model of that unit
    Brigadier General:
  • 8,546 Answers
Are you sure there IS bass? Or did you blow both woofers? Try headphones. Without a model number and more details (including the speakers) we can't do much more than guess.
Posted on Aug 05, 2010
Can I use this receiver with my 50 watt max speakers?
Yes.
However; there are quite a few factors that are going to effect the performance you'll get with this equipment combination while ensuring you won't damage them. Speaker design type and what you'll be listening to with them are just the basic of basics.
Do not attempt to drive additional bass. It is probably best that you adjust the bass with the tone control to roll it back below input level.
If you hear distortion of any kind, it's too loud.
Dec 26, 2014 | Yamaha HTR-5840 Receiver
Can i use a graphic equalizer with a yamaha as-500
My Yamaha Equalizer is Model GE-30. Review the manual for this unit and on page 3 you will see the connection procedure "Line Out" on the equalizer to "tape deck in" on the amplifier. In the case of the A-S500 user manuaI on page 5, I used the "line 3 " also identified as "tape deck" to connect the equalizer.
The front control(s) from page 2 on the A-S500 manual are then set :
Control(5) input selector set to Line 3 (Graphic Equalizer)
Control(8) REC OUT selector to CD (for CD), line1 (my blu-ray player, or tuner (my DVR/tv)
The only thing I lose is "PURE DIRECT" does not fuction if the equalizer is on, otherwise;
I simply set Control(5) input selector swith to the desired input source, the equalizer no longer
functions and "PURE DIRECT" can now be used.
The rest of the tonal controls for bass, treble, balance, and loudness work as they should.
Jan 29, 2013 | Yamaha AS500 Amplifier
My speakers are playing through the tweeters only (i think). there is no bass whatsoever, but the speakers do not sound blown. i have tried adjusting all of the bass that i know of. the model number for...
For all we know you have the speakers defined as 'small' and all bass from their channels is being redirected to a subwoofer. Have you looked at the manual and adjusted all the speaker levels with test tones?
Sep 13, 2011 | JVC RX-6000V Receiver
The control for the Effects Loop Mix seems to function like a master volume control. I get no sound in ay channel if the Effects Loop Mix control is in the "EFF" position (right) and sound...
That is the way it is supposed to work... It is a level control to control the level sent to an EXTERNAL effects unit. What external effects unit are you using? Brand and model please. If you proportion more to the effects loop, you want to make sure the EXTERNAL effects unit is on and its gain controls are up. The foot switch input should control the EXTERNAL effects unit when you plug the footswitch into the EXTERNAL unit. The footswitch input on the amp itself has NOTHING to do with the external effect loop, it only affects the amp's own DFX unit.
Jun 25, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi. I have bought a Behringer Bass Synth BSY600 and a Boss FV-300L Volume / Expression pedal. Both work on their own but i can't get the Expression pedal to work with the Bass synth. The expression...
The FV300l WILL NOT work tying it into the EXP of the BSY600. What you need to do is to run your guitar into the IN of the BSY600 and use TWO audio cables from the BSY600 output, the OUT and the DIR out and run those into the two IN's of the FV-300L. Then use whichever function by connecting the two OUT''s of the FV-300L to two channels of the mixer or a two channel amp so you could proportion the BSY600's effects as desired. You could also just use whichever out from the FV-300L you want which originates in the BSY600. The BSY600 is made to use an expression pedal that is a single TRS plug which is simpler, but you can use your FV-300L as I have described just as well, it just can't use the EXP input of the BSY600.
Jun 22, 2011 | Behringer BSY600 Bass Synthesizer Ultimate...
Why does the Clarion 2001 have a left and right channel input if the output is mono?
reason is there is separate bass on both input channels that you want to include in the sub channel. For example, if bass drum is on left channel and bass guitar is on right channel, you need both to hear all of the bass music from your single sub. OK?
Dec 11, 2010 | Clarion APA2001 Car Audio Amplifier
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
No Surround and Multiple Inputs Play at the Same Time
Thank you so much!
That completely fixed mine!
Thank you!!!
Jun 04, 2007 | Technics SA-DX930 Receiver
138 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
