Question about Frigidaire Affinity ATF7000E Front Load Washer
The washer will not spin and will not drain out I had a service person in he said the barrings are gone and the washer is not worth fixing the washer is only three years old can it be fixed for a reasonable price
  • 119 Answers
IT WON'T SPIN UNTIL THE WATER IS DRAINED OUT. CHECK YOUR PUMP, IT'S EITHER CLOGGED OR YOU HAVE A BAD PUMP. GOOD LUCK
TIMOTHY 714-334-1998
Posted on Aug 04, 2010
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
I have a neptune top loading washer. Call PSEG service man out (had contract on washing machine). will not repair cost too much. Problem. end cycle spin -water will not come completly out of cloths....
Yes Elizabeth if you don't DIY the fix it's no worth having a repair service touch the machine.
I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
Aug 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Wont drain or spin, we have drain it and started it again and it still wont drain
The pump is either broken or the drive shaft coupler is bad. My wife and I recently fixed our washer. i was inclined to get a service person to do it for $300 bucks but she started to take it apart. It wouldn't agitate, but it would pump. The coupler ended up costing us $17 dollars and we fixed it. Hope this helps.
Jan 22, 2011 | Samsung WF203ANW Front Load Washer
I have a kenmore series 70 washer, top loading. It filled up with water and then stopped. I have tried other cycles, but nothing happens. The water won't drain and there are no noises. Nothing happens no...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24712300
Also see the Whirlpool Service manual for top load, direct drive washers including test procedures and a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you manually move the timer to the spin cycle and it drains and spins, the motor and transmission are OK.
If it won't do anything after filling, the problem points to the timer or motor.
It is relatively easily repaired but you'll have to decide if the cost is worth the repair.
Personally, I tend to fix rather than replace so I'm probably not the one to ask.
Oct 31, 2009 | Kenmore 24712 Top Load Washer
Clothes are still soaking wet after spin cycle
But is the washer empty, if there is still some water in it, there could be something in the drain line,
if all the water is gone, then it sounds like the washer is not reaching the full speed of the spin cycle.
Unless someone can remove the drain line and check the pump, and check the clutch of the machine,
I am sorry to say you should call an appliance person and have them make a service call.
If you where to post the model # of the washer, someone could look at the manual of it and see
how the washer works and what the pump is. I hope it is a simple fix for you.
Mar 21, 2009 | Washing Machines
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
My washer does not drain. Water accumulates even after the rinse and spin cycle. The machine does not overflow water. Could it be that the discharge pump is causing the problem? Second, if that is the...
BE CAREFUL FLOOD POSSIBLE
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
A&E Factory Service
1-800-905-9505
Good work
Thank You
Neil
Jul 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Drum on washer wont spin
The belt is gone and or snapped off or the transmission is shot! And it's not worth replacing an old transmission.
If it's 10 years old or more buy a new one
and save your money ,fixing it is a waste!
A&E Factory Service
1-800-905-9505
Good work
Thank You
Neil
Jul 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Affinity ATF7000E Front Load Washer Logo
145 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
