Question about Whirlpool Duet GHW9150P Front Load Washer
The "control locked" light stays on and none of the cycles will run. Thanks. LB
  • 119 Answers
LOOK ON PANEL FOR A PICTURE OF A LOCK OR PADLOCK. THERE SHOULD BE TWO LINES TO TWO BUTTONS. HOLD THE BUTTONS FOR 3 SECONDS
Posted on Aug 04, 2010
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
How to reset after cleaning
Once you run the unit through the cleaning cycles the light will clear it's self and start the controller on a new count down. If controller dose not clear the light then the controller will need to be replaced. Now with that the controller will still run the machine and work fine a control board is not cheep and as long as you clean the machine every 6 months it will be ok.
Sep 04, 2013 | Scotsman Ice Machine, Cuber, 1930 lb....
Cycle finished. Red light indicating door was locked was on, yet the door easily opened. Now, none of the functions work. I cannot get the 'control on' button to work- none of the other functions light...
Hello & Welcome to FixYa
First try to reset the controls by pressing the END OF CYCLE button and hold it for 15 seconds. If the problem returns then check the door latch switch assembly and blow some air on that so that if dirt is stopping it from working it works again. If the problem returns then replacing the door lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 02, 2011 | Whirlpool Washing Machines
How do I get the "Control Locked" light off. None of the controls respond when it is on.
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool GHW9460PL0 front load machine about 4-5 years old. I was using it one day and the next the only thing that happens is the control locked light stays on all the time. any ideas? The...
Thanks for using FixYa. To resolve this issue press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 30, 2010 | Washing Machines
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
3 seconds. The indicator light turns off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
