Question about GE WCVH6260F Front Load Washer
Ge front load wcvh6600.
My washer wont power up, but the display says door locked. it wont run any cycle at all. can it be reset besides unplugging
  • marcmendoza_ Feb 20, 2009
    i have the same Problem and im looking for a good price on a new pump those pumps are about $165 at GE!!!!!!!. I believe the cycle stops because it wont drain. Mine stopped but by door unlocked and now i cant open it or run it because it wont drain. it will not start a any new cycles either.
Take the bottom panel off three screws and put your hand up where the door is located feeling blindly for a plastic latch....pull the latch to manually unlock door..... then with the door open unplug washer and wait 10 minutes...even if you have done this before this is different b/c the door will be open....still open plug back up and turn on..if the display comes on its the door lock...about $94.00 if no display its the panel board and that'a about $ 200.00...hope this helps too
Posted on May 29, 2010
Our door kept sayin "door locked". a technician came out to see it and said it was the door lock but that he had temporarily fixed the problem. he said to call if it happened again and would have to order new door lock which runs about $160. after six washes it said door locked again. he came out agian and within 5 minutes of diagnosis said it need a new door lock. i was furious bc i had already payed him and found an new door lock on Ebay for about $70. Got the manual off the internet and had my hubby replace door lock. not very hard except when he replaced it it still said dook locked. after several hours i told him to unscrew the bottom panel because i had seen tec do the same. to our amazement, one of the wires had come loose and needed to be plugged back in. amazingly it started working perfectly. then , i put a big load of towels in and it started shaking badly again and the same problem reoccured. DOOR LOCKED. so we took the bottom panel off and the wire had com loose again. we stuck it back in and wah-la... it worked again. this has happened about 4 times now and everytime we just open them bottome panel and replace wire. i believe we never even needed the new door lock to begin with? we havent checked putting the old door lock back in but i bet it would work because it looked like nothing was wrong with it when we took it out. I hope this helps before you spend an extra $200 or so like we did for a loose wire. we have now just left the front bottom panel off and when it happens, i just bend down and tighten. Hope this helps.
Posted on Apr 18, 2010
  • tbartoletti Dec 17, 2010
    I had this problem. I opened the bottom panel and it was full of water. Decided it was more than a loose wire and called for service. The service tech found a hole in the rubber gasket around the tub - it leaked into the door lock wires and caused it to short circuit. He replaced the gasket and it works again. For now anyway, this washer is a piece of sh!!.
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Reseting of spin / wash cycle
dont know how old, but get those techs back to fix ,call their boss ,call GE and complain
Dec 31, 2008 | GE WCVH6260F Front Load Washer
Constant resetting
it may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
Lock on the machine
Held in the lock button we found for 3 seconds.
Sep 14, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE WCVH6260F Front Load Washer Logo
669 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
