Question about Frigidaire Dryers
The dyer still works but it makes a loud noise and doesnt produce the same amount of heat as before
  • 119 Answers
LOUD CLUNKING NOISE WHEN THE DRUM TURNS? IF SO, YOUR ROLLER BEARING IS BAD. AS FOR THE LESS HEAT, YOU NEED TO CHECK YOUR VENT, MAKE SURE IT'S CLEARED. IF SO, YOU HAVE BAD COILS
TIMOTHY DO 714-334-1998
Posted on Aug 04, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My dyer is working it's just making a really horrible loud noise what could it be?
possibly worn out Support wheels.
Worn out Idler off the motor
Jun 03, 2015 | Dryers
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
My dyer does not get hot
  1. Considerations
    • A dryer needs the proper voltage to produce the correct amount of heat. If your dryer isn't heating properly, it's possible that the power supply is the problem. Make sure that the dryer is firmly plugged into the outlet, and if you have a circuit breaker or fuse panel, check to make sure that everything is in working order.
    Theories/Speculation
    • Several things affect a dryer's ability to do its job. If an external source isn't causing the problem, then the dryer probably has a faulty part. Possible culprits include a damaged or burned-out heating element, a blown thermal fuse or damaged wiring, all of which will require replacing.
    Warning
    • The San Diego Fire-Rescue Department recommends having your dryer serviced by a professional repair person. If the problem is caused by something within your dryer's mechanism, you could make matters worse by trying to find and fix the problem on your own. With the exception of checking the dryer's external power supply, you should leave troubleshooting to a professional.
PLEASE RATE THESE SOLUTION
Jan 15, 2013 | Dryers
Ge profile is making loud squikei noise how to fix it
is it a scraping squeak or a squealing noise?
Jun 09, 2012 | GE Dryers
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
2005 Buick LeSabre heated seat not working
The heated seats have relays that run them. Not quite sure where they are located but. That noise is the relay clicking on and off. They are actually pretty loud. Look for faulty connections to and from the relay and check battery power to both sides of the relay.
Dec 30, 2008 | 1999 Oldsmobile Aurora
Dryers Logo
91 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
