Question about Kenmore 82822 Electric Dryer
I have a Kenmore 110.82826102 Dryer that recently quit. I replaced the electronic control board and that solved the problem. Three months later I got an E1 error code indicating the thermistor is bad. Replaced the thermistor but that did not seem to fix the problem. If I run the diagnostics, I get a 08 software revision code. Does this mean anything? The problem appears to be intermittent as I can sometime get the dryer to keep running if I run through the diagnostic test and the restart the dryer. Are the control boards known to fail regularly? Is my only solution to replace the electronic control board again?
  • 90 Answers
SOURCE: Kenmore 11060052991 No start
have you checked the thermal fuse, if bad replace and clean vent.
Posted on Jan 05, 2008
Illeagle
  • 525 Answers
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
dmftrucker
  • 1922 Answers
SOURCE: First I had an E1 code, replaced the Thermistor then E2
check the ribbon cable to and from the control board for small breaks and make sure to clean the contacts gently by removing and replacing the cable too,try this
Posted on Nov 05, 2009
heatman101
  • 43501 Answers
SOURCE: when pts switch is pushed
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 05, 2011
  • 1606 Answers
SOURCE: my kenmore elite 4 dryer
Check your connections to the control board; maybe one is loose. If all of them are good, it is possible the new control board failed due to a manufacturing defect. See if you can get it exchanged.
Note: electronic circuit boards are easily damaged by static electricity. Handle them only by the edges; touching the circuitry can send damaging high voltage into it even if you don't feel the spark. Never set the board down on a plastic surface unless it is an anti-static bag or mat. If you must lay down the board, either put it back in the anti-static shipping bag, or lay it component side down on a hard surface.
Posted on Jul 15, 2017
My kenmore elite 4 dryer
Jul 15, 2017 | Kenmore Dishwashers
What is the cost of the machine control electronic system for a kenmore elite model 110.8772?
From Sears Parts Direct, the dryer electronic control board for the 110.87721700, W10339957, is $230.35. The user control, WPW10110646R, is $144.99. I didn't see the control board as in stock at other appliance parts vendors.
Since there are 4 extra digits in the model numbers for Kenmore dryers, please add a comment the full model number of your dryer. I will be glad to check if this is the correct part for your dryer.
I hope this helps.
Oct 29, 2016 | Kenmore Washing Machines
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Elite he3. What does code f01 indicate?
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
Error code on dryer F01 Kenmore Elite HE3 Dryer
Nov 19, 2015 | Kenmore Dryers
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
I have an F40 code on my Kenmore Elite Dryer, model # 110.67092600
Fault code F40 is a communication error between the machine control and the motor control. Disconnect power then remove three screws from the rear of the console assembly and pull console towards the front of the dryer to hinge open and remove console. You'll see three electronic assemblies; the machine control electronics, the motor control electronics, and the user interface electronics.
Visually check the communication harness, the three-wire harness that connects between the machine control electronics and the motor control electronics. Make sure it is fully inserted into both electronic controls and the terminal connections are clean. Reseating the connections several times will help clean off dirt and corrosion build up.
Do the same with the the wire harnesses connected to the motor control electronic assembly. Make sure they are clean and fully inserted into the control. It is a good idea to do the same thing with all other wire harnesses in all of the electronic assemblies.
Aug 09, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Sep 03, 2008 | Kenmore Elite HE4 Electric Dryer
Replacing saftey thermostat monthly
Clean dryer vent to improve airflow so dryer will not cycle on high limit thermostat. The best way is to use a cordless drill vent cleaner designed to clean dryer vents. Manual brushes are also available, or you can disassemble, clean, and reassemble vent. (if so, use the foil tape when reassembling) Make sure you are not using flex dryer venting. This should also improve dryer performance, reducing dry time.
Jul 10, 2008 | LG DLE2532W Electric Dryer
Kenmore 82822 Electric Dryer Logo
197 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
