Question about Teac AG-D9320 Receiver
When turning on Teac AG-D9320, I got msg "PROTECT" and it turned off automatically. What could be the problem
4 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: teac ag-d9320 5.1 receiver fuse
Make sure the fuse you put in matches the power requirement of the device you're installing the fuse into, putting a fuse that does not handle the current will cause this, but do not overshoot as this may fry your device - it must match. If you know it's matched, then the device you're installing the fuse into may be faulty in such a way that it is drawing the wrong amount of power. This can be due to the power supply on the unit.
Posted on Sep 07, 2007
Hawk007
  • 5 Answers
SOURCE: Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Posted on Jan 07, 2008
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
NEED MANUAL FOR TEAC-AG 9320
use a search engine (I used Google)
"Teac AG-D9320 manual"
retrevo.com has the link
Aug 11, 2011 | Teac AG-D9320 Receiver
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
Help with AG-D9320
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Teac AGD 9100 user guide
Click on your brand name Teac (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line. And dont forget to rate me, on this great site.
Dec 25, 2007 | Teac AG-D9320 Receiver
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
TEAC Amp
The amp is going into "protect mode". This means there is a bad part or parts being detected. Professional service will be needed.
Sep 13, 2007 | Teac A-1D 2-Channel Amplifier
Teac ag-d9320 5.1 receiver fuse
Sep 07, 2007 | Teac AG-D9320 Receiver
Protect
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Jan 22, 2006 | Teac AG-D8900 Receiver
Teac AG-D9320 Receiver Logo
106 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
