Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
My dishwasher not starting when I select the 2 hour delay start, any suggestions?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be an issue with the timer that has gone bad, they don’t often fail but if everything else is working fine then it is the Timer that has gone bad and needs to be replaced. If the timer appears to be working fine then the issue is with the heating element which is not heating up water and as the water is unable to reach a higher temperature the unit stops at heating cycle i.e. rinse... To resolve this issue you’ll have to repair the heating system problem. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 04, 2010
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
Brada dishwasher won't work, display just counts from 0-24 when the door is shut. Any suggestions to the problem?
Hello. From the symptom you describe, it sounds like the delay feature is enabled. This can happen if the power was interrupted(outage). The delay allows you to have the unit come on after whatever number of hours you select up to 24. A customer of mine had the same problem--get your manual and follow the directions on turning off "delay start". I hope this helps you!--Let me know the outcome or if you need more assistance!---Thanks!
Oct 16, 2015 | Dishwashers
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
What does a 5h code indicate
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
Feb 07, 2015 | GE Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
I like to know what is delay start option on my dishwasher?
Hi, It is so you can set the dishwasher up to run at a later time. If you set a 2 hour delay, it will wait 2 hours and startt on its own.
Please let me know if this helps you.
Vic
Jul 15, 2009 | Dishwashers
We have a Dishlex Global 500 dishwasher, electronic. How do you get the delay start to function?
You select "delay' and as you keep pressing the delay key the hours of delay will increase by the hour.
May 26, 2008 | Dishwashers
Time delay
1.Position the rotary switch to reset.
2.Press the RH button, with the clockface on it, once for every hour of delay required. The display will change to 1H, 2H etc.
3. reposition the rotary switch to the number of the required program.
4.Washer will start program after the selected number of hours.
NB. If you select too many hours, cotinue to press button as display will count up to a maximum of 24H before retuning to zero again.
Jan 24, 2008 | Indesit 24 in. DE73 Evolution...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
21 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
