Question about Pinnacle Solene SLP10 Baitcast Reel
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
  • 3 Answers
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Posted on Jan 01, 2011
  • Cuivre Aug 04, 2013
    The drag has nothing to do with cast control- you mean to say "cast control tensioner".
  • 3 Answers
Keep thumb on spool, Put in free spool cast smoothly and release thumb at about 45*. Look at aim point following line down. Thumb spool IMMEDIATELY line hits water.
Posted on Sep 23, 2010
What lb test fishing line does the 112 Oceancity fishing reel take ?
Is this the vintage 112 casting reel?.. You can use almost any size line that the reel will comfortably handle... too small and you might lose fish..and take miles of line to fill..... and .. too big and the reel will not function efficiently..its almost a judgement call.. use common sense..If you need a very small line.. you should use a "backer" to keep from using 1000's of feet of line to fill the spool..... and .. If you need a very heavy line... maybe a bigger reel is in the future... hope this helps..
Jul 22, 2017 | Fishing
When I cast the line the spool unravel inside and tangles a guy I ran into says I need to set some stuff can you explain to me what I need to set
Pete, you are talking about a fishing reel correct? Check the attached links video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tips on Fishing with Spinning Reels
10 tips for proper reel care
Reel Maintenance Instructions
Which one to Choose Baitcast Spincast Spinning
Apr 11, 2016 | Fishing
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
The line will not release when I cast
I am assuming you know at least something about fishing with a baitcast reel. If you do not, make sure you release the thumb button when you cast.
Chances are your line is either tangled or dirty on the inside. Also, the longer the line sits on the spool, the "curlier" it becomes, making it more difficult to get a good cast. I would suggest replacing your line.
If that doesn't help, then its possible that the release pin isn't releasing when the button is released. If this is the case, it is probably time for a new reel. Zebco 33's are inexpensive, and not really worth the trouble to try and repair- better to just invest in a new one.
Aug 08, 2014 | Zebco Spincast 33 Reel
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
May 19, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Think it may be a line tension problem. every
Wow, I can't believe that. That reel is very simple and shouldn't do that. I would guess that it's a problem with the line. Usually a real like that comes with line. Sometimes line is bad and it's very twisted due to being the last on the spool before it's put on your reel. I would suggest you buy some quality line, like Trilene or Stren and use about 6 lb test. I like the limp kind (read the box and it will tell you what type you are buying). Limp line means fewer twisting/tangling problems. Good luck. Alley
Jul 26, 2009 | Sport & Outdoor - Others
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Wont cast
if u pushed the release button it will automatically lock if u real it wen u are finished casting make sure u put d catch bak on for the line to retrieve to ur reel
Mar 22, 2009 | Pinnacle Solene SLP10 Baitcast Reel
Pinnacle Solene SLP10 Baitcast Reel Logo
1,740 people viewed this question
Top Pinnacle Fishing Experts
Tom Chichester
Steve P
Steve P
ray gallant
Are you a Pinnacle Fishing Expert? Answer questions, earn points and help others
