Question about Dryers
My dryer turns on for 30 seconds, i can see the flame burning but then it shuts off.. i already changed the coils but it still doesnt work what could it be
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Could be a bad flame sensor, a kinked gas line, or you can have a restriction in your vent.
Posted on Aug 04, 2010
Dryer doesnt work on settings
I have repaired (2) gas Maytag dryers that appeared to have timer issues. In both cases, it wasn't the timer, but the temperature sensors. In both cases, I replaced them and the dryers operated A-OK. The sensors signal the timer to advance. One sensor is located just beyond the flame where the gas is burning, the other just before the squirrel cage blower. In addition, there are (2) electrical coils located in front of the gas igniter assembly. If replacing the temperature sensors doesn't fix the issue, then replace the coils.
Apr 06, 2014 | Maytag Dryers
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 28, 2011 | Dryers
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
Gas dryer. ignitor works. will turn on flame, but flame will only last anywhere from 30 seconds to 1 minute. then it will shut off. sometimes it will turn on again, usually it will not. i have to turn it...
check the gas coil valves on the gas valve as they get weak and cant keep the valve open to supply gas to the unit,otherwise it could be the heat cycling switch located on the burner tube thats getting bad
Mar 12, 2010 | Dryers
Model 110.74852400. How do i get to the coils to
Just changed the coils on the same dryer 110.74852400 but problem not fixed...flame burns for 30 seconds and shuts off...relights in about a minute, than burns 30 seconds, shuts off...any advice??
Oct 03, 2009 | Kenmore 73952 Gas Dryer
Dryer's flame cycles but will not burn
Check the following to address this issue..
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Furnace blower motor turns on with no flame burning
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
Marvin
Marvin
