Question about MTX Thunder 4250D Car Audio Amplifier
What could it be if the amp heats up - MTX Thunder 4250D Car Audio Amplifier
  • 70 Answers
It could be there is no air circulation or the fans are broken
Posted on Aug 04, 2010
Testimonial: "very good"
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 31, 2012 | Electrical Supplies
Wiring honeywell th8320u1008
Be sure you are looking at the letters set up for heat pump. Orange should be "O". Remove jumper between w2 and e. Then be sure you have the settings correct in the tstat for a heat pump with back up heat. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 28, 2017 | Heating & Cooling
Dead, has power going into wiring, but wont do anything no lights or nothing could it be the thermal fuse?
It is almost definitely the thermal fuse. However, you also need to determine why it blew the thermal fuse. This fuse is in place to protect the Control Unit from overheating cause by to high of an amp draw from the motor, the heating element, or a dead short in one of the solenoids.
Replace the thermal fuse, which is located on the Control Unit, behind the Control Panel. After replacing the thermal fuse, start the dishwasher and using an amp meter, test the amp draw of the unit at the supply connection.
During the water fill, you should only see 0.1 to 0.2 amps at the most, and possibly could show 0.0 amps. Once the wash motor turns on, you should see somewhere between 1.2 and 1.8 amps. If the amp draw goes over 2.0 and stays there, you have a bad wash motor.
The best way to check the amp draw of the heater is to put the unit into a field diagnostic mode. To do this, cancel the cycle and wait for the unit to shut down (standby mode). In this order, press "HI TEMP WASH - AIR DRY - HI TEMP WASH - AIR DRY". Air Dry could also be labeled No Heat Dry or something similar. All of the LEDs will light up momentarily and the heat element will be turned on briefly. The amp draw of the heat element can read from 5.5 amps to 7.0 amps. If the amp draw of the heat element goes above 7.5, chances are that your heat element is bad and needs to be replaced.
Apr 17, 2011 | Dishwashers
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
AC draws more current in hot mode
If this is aheat pump or reverse cycle unit that amps in heating is to high. Should not go over nameplate amps in heat or cool. Sounds like maybe two things. Overcharge and stopped up coil on the inside air handler. The reason for the high amps is in heat the head pressure is higher than normal. So check the coil inside and have the charge checked because that compressor wont run long pulling that much amps over nameplate. Keep in touvh Rus.
Nov 25, 2009 | Ruud Matching Split Air Conditioner
Will conditioner run same amps cold weather
Usually connected to a 30 amp & 40 amp double breaker, if it is a heat pump. 30 for cool, 40 for heat, to turn on 1 or 2 heat strips. heat strips are rated 2 5kw each.
Nov 12, 2009 | Carrier Heating & Cooling
Rheem Heat pump 5 ton heat strip 10KW what
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
Oct 09, 2009 | Heating & Cooling
MTX Thunder 4250D Car Audio Amplifier Logo
48 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
