Question about Karcher 2500 PSI Pressure Washer
Honda 2500 pressure washer,
I see water ,and white goo coming from the rear of the engine
  • Anonymous Mar 31, 2014
    Cracked pressure outlet of pubp
  • 14 Answers
The problem is leaking oil seals. Remove pump assy and change the oil seals fitted in the valve guide plate. It makes good practice to replace the high pressure seals at the same time
Posted on Mar 11, 2009
The oil in the front of the washer turned a cream color...like it has water in it. Any comments?
Posted on Jun 02, 2008
Overfilled the oil and black smoke came. Can't startt now what i need to do
hi there pauly46 here
remove plug, pull engine over to remove oil from combustion chamber , clean plug,
refit, remove air filter - replace it if its wet with oil / or water damaged and clean backing plate , drain float bowl and check oil in carb, refit bowl and connect water supply to pump - turn on and start engine ( sounds like you hydraulicd the piston in the cylinder )
engine may blow blue / white smoke for a while then settle back
note do not use a sae 30 , use a 20w/50 oil or 10w/40. honda engine with low oil shut down
units on them have a problem with sae 30 oil
cheers hope it helps
pauly46
May 13, 2011 | Karcher 2500 PSI Pressure Washer
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
I just finished setting up my Homelite 2500 and turned it on. Once running to 30 seconds it let out a loud pop they scared the hell out fo me. I truned off imdeiately in fear of ruining the engine. Any...
Buck up now. You did good turning it off. Check the oil and water as described below and then fire it up again.
The power washer is your friend, but do NOT wash off your shoes while wearing them. Or rinse your dog or your hand >> it will blow a hole in aforementioned.
1) Your water has to be turned on before firing up the pressure washer. Simply squeeze gun trigger while starting engine. Do NOT wire the trigger closed to start or use power washer wand. That is a good way for the thing to break free and punch a hole in your pants.
2) You need oil in engine and in pump > engine oil comes about half way up dip stick > pump oil comes up to middle of viewing window on pump head.
That's all there is to know. I think your new engine had a growing pain, and things are fine.
Honda is a good engine. We ran our first Honda power washer for years until it fell off the trailer upside down and the chain kept it tied to the trailer until the gas tank was sanded off by the freeway after which it caught fire for a bit. You will have better luck.
Oct 06, 2010 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Jun 29, 2010 | Honda 2500 PSI Gas Pressure Washer
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Water comes through nozzle, but no pressure. it is a john deere, with a honda engine.
The engine doesnt matter. Most pumps are DeVille Bliss. Get the model off the pump and go to their website for trouble shooting information.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
776 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
