Question about DKNY 1009 Wrist Watch
How do you remove the links form the DKNY 4351ladies watch?
  • 103 Answers
There are pins in the watch the pins have one large end and one small end you want to push the small side into the watch, make sure the pin can come out the other side you can use a thumb tack usually.
Posted on Aug 04, 2010
L have a DKNY WATCH model no. NY4062 unable to get back off to replace battery can you please help
Take your DKNY watch to a jeweler for a demonstration of the non-destructive way to remove the back. You may even be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
Mar 25, 2018 | DKNY Watches
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
Cam i get spare links for dkny clear links watch
yes Dkny will give you free links for your watch if you need them . DKNY watches are made by fossil watch company, you can contact them at this telephone number# 1-800-449-3056 to have watch links sent to you.
Oct 14, 2010 | Watches
I-have-a-ny3715-watch-with-a-stone-missing.it-was-bought-in-new-york-last-november-i-have-the-reciept.i-have-tried-local-jewelers-but-they-cannot-fix-it.how-do-i-get-it-repaired-
Your best bet is to contact DKNY to see if they can replace it for you. Other then that, I would try a local jeweler. Here is a link for the DKNY service center: http://www.dkny.com/contact/ Good luck!!
Aug 12, 2010 | DKNY 1009 Wrist Watch
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 | Watches
The link on my dkny watch has broken and I would like it repaired where can I send it
Hi
Thanks for using FixYa. You can get it repired from an authorised DKNY service center or can also get it done from these tech.s--
Watches Repair Link
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | DKNY Watches
Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Dec 26, 2008 | DKNY 1009 Wrist Watch
Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Mar 09, 2008 | Watches
DKNY 1009 Wrist Watch Logo
3,266 people viewed this question
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
