Question about Viper Security and Remote Start System (basic install included)
Programming remote ezsdei489 to viper 5000 alarm? go to start car today batteries dead. i hook jumper cables to it and immediately alarm goes off. remote seems not to be programmed.
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Viper Remote Start, Jeep Grande Cherokee, Going crazy!
no - unfortunately "any mechanic" does not have the training to troubleshoot an alarm system, and a dealership does not work on anything aftermarket.
Your best bet is to visit DEI (Directed Electronics Inc.) website and find an authorized dealer near you... most likely a car audio shop.
Best Buy usually hires newbies as installers and they dont have much experience... Look for an independant shop.
CLICK HERE to go to the Viper Site. (Find a Store is at the top of the page)
The brain module cannot be repaired - the ignition and starter relays are integrated on the controller board. Since it is 2 years old - there may not be a replacement part available.
Good Luck!!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 06, 2009
VZW
SOURCE: Viper remote stopped working!
First things first. Check the fuse that powers your alarm system. If that seems to be ok then try the next simple option. Open the hood and disconnect the negative battery cable. Then turn the ignition to the start position for approximately three minutes. This will allow for any remaining energy to dissipate from your system. Now you can reconnect the negative cable. *** Before trying your alarm *** turn the ignition on and off 3 times quickly. Make sure you don't start the vehicle. Now you can exit the vehicle and try your alarm. FYI you can always stop at a nearby Best Buy store for additional assistance. They are usually very helpful. Good luck and best regards, Rico...
Posted on Sep 13, 2009
  • 1455 Answers
SOURCE: i lost my remote for my viper 350 hv,and when i
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Posted on Oct 08, 2010
SOURCE: How do I program a Viper 473 V Replacement Remote,
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Posted on May 12, 2011
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
My car battery went dead, bought a new one, every time I hook up positive cable, car alarm goes off........
remove alarm reinstall after fitting. at least cut power supply and back up supply fit battery repair reinstall alarm.
Feb 16, 2015 | 2004 Dodge Stratus
I have a 1996 jeep grand Cherokee the battery went dead tried to jump start it but the alarm just goes off every time i turn over the key so i tried using the key in the door to turn the alarm off but it...
Try closing the doors then hook up jumper cables, let it sit for a couple of minutes with cables hooked up and other vehicle running. Then try to use key to turn off alarm before opening door. Then try to start it.
May 10, 2011 | Jeep Grand Cherokee Cars & Trucks
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
My car alarm is preventing my car from starting w/ a dead battery
check remote batt..if that dont work unhook car batt for 24 hrs. should reset
Nov 29, 2009 | 2001 Honda Civic
1997 Honda Civic: Battery died and the Alarm won't disable
If you hook up the jumper cables can you disable the alarm with the remote?
Jun 24, 2009 | 1997 Honda Civic
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
Problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Dec 28, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper Car Alarm problem
My initial thought is the alarm somehow drained the battery down so low that there's not enough power to even turn on the LED or start the car. If that's the case, getting a jump from another vehicle should at least let you disarm the alarm and start the car.
Beyond that, you'll probably need to reference the manual for your model alarm. You can find the manuals here.
Mar 27, 2008 | Car Audio & Video
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
227 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
