Question about Dell 3100cn Laser Printer
I have an error code "Restart Pinter" #004-321. Printer quit working and none of the buttons work. Have turned printer on and off, disconnected printer connection to computer and nothing seems to change the error message. Any Ideas? Thanks Bob
    President:
  • 3,278 Answers
Hello, Bob.
From Dell Support:
The 004-321 error is caused by the IBT Home position sensor failing to detect the metallic foil attached to the IBT belt.
If you remove the print drum from the top of the unit and place it on a clean flat surface (green drum down, being careful nothing contacts the green drum) and orient the drum unit so the "pointed" end is facing you, you should see a rubberized belt.This is the IBT belt and is what carries the image while the image is being built. This belt should be centered between each side wall of the drum unit. Yours probably isn't.
If you remove the screws that attach the top cover, you will find angled rollers that center the belt. One of these may not be mounted correctly.
Hope this helps
Posted on Aug 04, 2010
The scanner has quit working. Error message says printer cannot connect. Printing works find from computer. Copying too.
Switch off the scanner and disconnect the usb cable then restart your computer.
When the computer has booted up, reconnect the scanner usb. Try the scanner.
If the problem persists try re-downloading and installing the scanner software
Jan 20, 2016 | Office Equipment & Supplies
Hp 7960 printer
Make sure the paper try is properly attached. Try to unplug the power of your pinter and the USB cable for about 2-3 minutes. Restart your computer. Plug the USB and power to the printer then turn it back on.
Oct 04, 2008 | HP PhotoSmart 7960 InkJet Printer
Tip
Getting a Paper Jam error
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
4) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
5) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
6) Try to feed paper manually (using the paper feed button).
Else,
7) Before re-connecting the printer to the computer, uninstall the printer driver and restart the computer.
8) Re-install the printer driver.
on Aug 29, 2008 | Epson Stylus C88 InkJet Photo Printer
Printer keeps trying to print even after cancelation
Try reinstalling printer drivers, from disk or from Dell website.
Aug 21, 2008 | Dell 924 All-in-One InkJet Printer
Error code- print system failure code 0xc18a0501
Solution posted here is straight off the HP support site and didn't work for me. However, elsewhere in this forum is something that did!
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Feb 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Docuprint DP211 has error 006-370
006-370
Restart Printer
Contact Support
MessageReturns
Condensation may have occurred inside  the printer.
Do not use the printer for more than one hour.
If this does not solve the problem, contact Dell.
See "Contacting Dell" in the Owner's Manual.
Jun 04, 2009 | Office Equipment & Supplies
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
My printer
Start by disconnecting the printer from the computer and turning it off. Wait a few minutes before reconnecting it. While waiting, open your pinter settings and insure you have nothing waiting to be printed from you computer. Once this is verified, restart your computer, then reconnect the printer. Most likely the print que is simply "stuck" on the one file.
Jul 14, 2008 | Lexmark X2500 All-In-One Printer
Dell 3100cn Laser Printer Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
