Question about GoVideo Go Video DVD/VCR Combo
I have a Go Video DVR4300 DVD/VCR which I originally had in my bedroom connected to a standard definition TV through the composite video/line out audio jacks. A couple of years ago, I put the unit in the living room connected to a Philips HDTV through the component video and audio jacks on the DVD section, and the composite video/line out audio on the VCR side. Everything worked fine. Last night, I decided to move the unit back into the bedroom and connect it to a standard def TV. When I did so, I found that there was no audio from the VHS section on playback. There WAS audio from the DVD side (it's connected through the DVD/VCR composite video and audio line out jacks). The owner's manual mentions that if there is no audio on VHS playback, "you may be watching video through the component video or S-Video jacks". No, I'm not; the unit is connected through the DVD/VCR composite video and audio line out jacks. The TV I'm using doesn't have component or S-Video inputs. I even tried connecting the unit using the RF output. The quality was terrible and the audio was still missing on VHS. What do I do?
  • up_to_eleven Aug 04, 2010
    It certainly could be a bad IC on the audio section, but the VHS playback was working just fine less than a week ago, and only failed when I moved it into the bedroom. I didn't drop or bump the unit. Is it possible I did something wrong in connecting it?
    No, there is no factory reset in the menus, and there is no reset function mentioned in the owner's manual.
  • 4,889 Answers
Did you try scrolling through the different audio modes? Stereo, Mono, SAP etc.,? One of them should do the trick.
Posted on Aug 04, 2010
  • 1 more comment
    I did. There is a button on the remote marked "Audio". In VCR mode, it switches between (supposedly) Stereo and Mono. But when I press it while the tape is playing, it shows an up arrow, a down arrow and the word "MONO". Nothing I press changes this, and after a few seconds it goes away.
  • eagle338
    eagle338 Aug 04, 2010
    If he player has a headphone jack then you can just plug external speakers into it and solve the problem. It sounds like the best possible way out of this mess.
    Well, that, or take it to the local repair shop to see if it really is the audio IC, like the first guy said.
  • GoVideo Master
  • 19,396 Answers
Hi.
Check if in the menus there is a factory reset and try the factory reset.
    Thanks for the suggestion, but there's no factory reset mentioned in the manual or available via the menus.
    Also, there is no mute button on the remote, but there is a volume control, and it's all the way up, so it's not that.
  • GoVideo Master
  • 6,993 Answers
if the sound does not come up when you connected it via RF output, then it means the sound IC of the player is defective. Electronics could be funny sometimes, it might work now and later develop fault.
I would also advice you check if the player is not on mute.
Take care.
How do I connect old school dvd/vcr combo to LED HDTV?
The general rule of thumb is that R-W-Y outputs from the VCR/DVD combo plug into corresponding color coded inputs on the TV. I think the Y(ellow)/VIDEO designation indicates where to insert the Y cord. It's worth a try.
Feb 12, 2016 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lost the manaul for GO.VIDEO DVR4300
Hi well you can get a online version of the manual its the same thing go to http://tv.manualsonline.com/manuals/mfg/govideo_1/dvr4300.html and click on get manual I hope this helps.
Feb 24, 2009 | GoVideo DVR4300 DVD Player/VCR
No video audio connecters
If you have a VCR with RCA inputs and coax (cable) output to TV, try plugging the DVD players RCA outputs (L/R audio, composite video) to VCR RCA inputs. Then select the DVD input on the VCR and it shoud play just as a the VCR does. If you don't have a VCR, an RF modulator might be needed, but a VCR would probably be cheaper.
Jan 24, 2009 | GE 25GT240 25" TV
Can't get DVD/VCR on TV screen
Universal remotes are not universal....You may be able to find one button labeled as something else to actually change your input. Just have to try them all... Nothing replaces the original....
Jan 09, 2008 | Sanyo DS31590 31" TV
DVD4300
Be advised that this unit, the Go-Video DVR4300, is a combined VCR (video cassette recorder) and DVD Player; it does not record DVDs. Only a DVD Recorder unit will serve your need.
Instructions for recording to VCR from TV is in the manual.
Dec 14, 2007 | GoVideo DVR4300 DVD Player/VCR
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
DIRECTV/VCR/DVD
You will need a Composite video to RF convertor, this plugs into the antenna socket on the TV and then converts the signal from Composite Video into RF signal that can be plugged into the corresponding socket from ya target device. Try Ebay? look for an composite to RF convertor.
Jul 29, 2007 | RCA F25281 TV
GoVideo Go Video DVD/VCR Combo Logo
147 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
