Question about MTX Thunder 4250D Car Audio Amplifier
Can I hook up a 12 volt outlet to the secondary battery
  • 70 Answers
Yes you can but the best thing is to use a toggle switch so you can always turn it on and off
Posted on Aug 04, 2010
Plugged camper into 120 volt everything works electrically except ceiling lights dont work
* Check 12 volt DC system (may be camper battery or car battery, though most only use the camper battery.)
* Camper may be using 12 volt DC lights so it can be turned on while your on the road or not hooked up to an 120 VAC or 240 VAC outlet.
* If you are using 120 VAC lights then check the neutral line (note; HIGH voltage here. Get help from an electrician or at least the RV park handyman.) The problem may be at the outlet (the RV site's problem) or more likely in your plug or cable (the big cord) as it does get abused, run over, kinked, etc. Need to have it checked by an electrician.
* Check the light bulbs; is it seated properly? Replace if burnt out. Have electrician test if there is power at the socket.
* Final; Be safe and have a qualified electrician service your camper.
Aloha, ukeboy57
May 11, 2018 | Electrical Supplies
I have a 3000 watt inverter,with 3 plug in outlet..how much power do I get from 1 outlet..this equipment is hook to 6 12 volt battery charge by a 60amp controller and 3 solar panel of 265watt each???
You didn't mention what make or model of inverter. Lets assume you are in the USA and your inverter has standard the US 15 Amp three pin 125V NEMA 5-15 AC outlets. based simply on that you would have a max of 125 x 15 = 1875 watts per outlet.
Dec 07, 2016 | Solar Electronics - Others
How can I hook two 12 volt batteries together to produce 24 volt output. I have replaced the two older batteries but have not been able to get the two new batteries to produce the necessary 24volts
Hooking up 2 batteries (IN SERIES) will give you 24 volts. First make sure the 2 batteries are exactly the same. Do not use mismatched batteries. Hook the POSITIVE of first battery to the NEGATIVE of the second battery. Then hook your LEADS ( hot and ground) to the 2 remaining posts. That will give you 24 volts. When charging the batteries with a charger, hook the charger up to the LEAD POSTS.
Apr 26, 2015 | Boating
How to hook up a 12 volt battery from converter to fridge
on back panel there is a plug into outlet then on bottom below control board a bus shows 12 volt and ground
Aug 01, 2014 | Dometic RM2193RB Compact Fridge...
Add 12 volt outlet switched by ignition
Look in your owners manual for the accessory fuse. That line turns off. Also, consider a 12 volt relay between the seat and your power source. A small toggle switch will work well for a relay.
Dec 13, 2013 | 2005 Pontiac Montana SV6
12 volt lights not running on shore power ,just running off battery. but 120 outlets working fine.
check the fuse for the 12 volt system. Check wiring for the 12 volt side of the transformer and check if you are getting 12 volt out of the transformer.
Aug 04, 2013 | Electronics - Others
I really need the the battery pack to make work my Meade DS-114AT telescope? or I just need a transformer of 12V to plug in at the outlet to the wall?
You can use a regular deep cycle 12 volt battery-- or any 12 volt car starter battery. All you need is the correct 12 volt cigarette lighter style cable for your scope.
www.scopestuff.com should have the proper 12 volt plug for your scope.
May 01, 2011 | Meade DS114-EC Telescope
1996 Cavalier 12 Volt power outlet in car doesn't work right?
Even thought the plug in is 12 volt. It's ouput is different. Most electronics have different ranges from 3-9 volts.
Does the 12 volt charger put out 12 volts? If so, it would burn up the electronics' capacitors on their power supplies.
How is the car's electronics doing? Are they too failing? If so, that would be a faulty voltage regulator, if not, I would hook up anything you use to the radio wires.
You cannot plug in anything directly to battery no matter what the person told you. Batteries charge, than release charge, a contiuous cycle. The power output is speratic and anything hooked straight up to the battery will need a fuse.
Jun 08, 2009 | 1999 Chevrolet Cavalier
Toshiba MD20FP3 not turning on
Is a good thing the main fuse is not open,your problem is in the power supply ,as I understand you have no indication of power(no lights,No clicks)The 5 volts that power the microprocessor might be missing,this 5 volts usually come from a regulator,this regulator should have 12 volts in one side and the 5 volts in the other,the 12 volts come from the secondary of a transformer and it has its own fusible resistor,if the resistor is open is because the regulator is shorted and it need to be replaced.This is a good place to check.Be careful when checking this parts.If you are not too familiar with tv service seek the assistance of a servicer,it should not be too expensive.
Oct 03, 2006 | Toshiba MD20FP3 Combo
MTX Thunder 4250D Car Audio Amplifier Logo
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
