Question about Kenmore Heating & Cooling
My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
    President:
  • 2,559 Answers
When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
Posted on Aug 04, 2010
4 Suggested Answers
  • 11 Answers
SOURCE: not cooling
probably low on refrigerant
Posted on Sep 19, 2009
  • 415 Answers
SOURCE: Fan works but condenser does not kick on
You air handler and condensor run off of two seperate circuit breakers. They share the same control voltage source. With the air handler responding to the thermostat setting, we know you have control voltage. You either have a problem with the line voltage at your condensor or something is happening in the control. Check your circuit breakers and/or fuses to your outdoor unit. Also, look for a red button near the area where the refrigeration pipes enter your condensing unit. Push the red button. If it starts to run, your unit went out on High Head Pressure. A dirty air filter this time of year can cause head pressure problems in the heat cycle (assuming this is a heat pump). Also check for cleanliness of the condensor coil and ensure proper operation of the outdoor fan motor.
There are a couple of components inside the condensor that could prevent it from running. One is the contactor. If the contacts are pitted or if a bug crawled in between them, it will prevent the unit from running. Another component is the Dual Run Capacitor. If this fails, it could prevent operation of your outdoor fan and compressor. Don't forget to check all your wires and connections. Always shut off all power prior to reaching into the electrical compartment.
I hope you find this to be very helpful moving forward. :-)
Testing Run Capacitors
Failed Compressor Contactor
Posted on Apr 03, 2010
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Fan blows fine not blowing cool air acts like it is kicking on then just kicks in and out what could be the problem
Normally this is a sign of a bad compressor or a bad start capacitor. The capacitor you could do yourself if its the compressor buy a new unit. sorry
Aug 08, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
A/c unit is not blowing cool air. I took it apart and cleaned all the coils, but it still is not cool. There is also a sound like something is trying to kick on but it just kicks right back off.
sounds like the compressor is having trouble starting. this could be the start components or the compressor itself. if the fan is running when you hear the "kicking in" noise it is you compressor, they are generally PSC motors, that require a capacitor to start, the capacitor could be bad, or the compressor may need a start kit added to it, they are available to the public at most appliance parts houses, you will need the model and serial number of the unit to select the proper one.
Jul 30, 2009 | LG LWHD1800HR Wall/Window Air Conditioner
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
Fan blows but compressor does not run.
turn off asap! the compressor is the heart of your system, so it might need a hard start it gives it more power if that does not work be ready to pay for a new outside part
Oct 16, 2008 | Carrier YCB213D Air Conditioner
Air conditioner
Hi!!
It not uncommon for the condenser motor to blow out, if evertything else is ok. The unit will kick in normally and you'll start getting cold air inside. Since the condenser is not doing its job, the unit's thermal protection will cut off compressor until cools down and then will start again.
Replace condenser motor (around $100) ASAP and do not use unit until then, othewise, major damage to the unit can occur.
If helpful, click below. GOOD LUCK
Aug 04, 2008 | Intertherm P3RA-042K Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
