Apple MacPro 8 Core No video, i get startup sound, fans come on,, LED's come on,, its not the LCD.. I work on PC so i would like to get some help fixing this MacPro
  • 1 more comment
  • Matthew Albert
    Matthew Albert Aug 04, 2010
    ty NinaE, but this is a MacPro desktop not a MacBook,
    the video card is a ATI not Nvidia.
    any Mac Tech's out there?
  • Matthew Albert
    Yes swapped it with a older card [PCIE], but same problem,
  • Matthew Albert
    Matthew Albert Aug 06, 2010
    i reflowed the gpu and got it to work. i will get a backup video card
    ty
  • 11,800 Answers
It's almost surely a failed ATI video card but you must do some testing to be sure.
First you must disconnect all hard disks and try to boot to BIOS without them - if you can't then it's a hard problem
Then obtain another PCI-E video card (whatever the type) and try to boot with it - if you can then your card has failed; if you can't then the problem is in the motherboard or the power source.
Finally replace the power source - if you can boot in the BIOS then your source is dead, if you can't it's the motherboard.
Posted on Aug 06, 2010
Testimonial: "it was the v card i repaird the gpu chip and all good, do i know you? your id i remember from my dod days. im CIA JONNY BLAZZ. "
  • Azrael SRL Aug 06, 2010
    If you had problems even with an different card then you should check the power source - it may be ageing and no longer at full power and the PCI-E connector - you might need to press on the card a little more strongly when you install it, it got loose and is no longer making perfect contact.
  • 4,281 Answers
For that open cpu cabinet cover then find motherboard . Reconnect RAM memory clean dust from all parts. Pull processor and it's fan then reconnect both. Remove pci card if any reattach vga card pull cmos cell from motherboard for 10 minutes then put it back then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 04, 2010
    President:
  • 567 Answers
Hi the video card seem to be bad you should replace it
  • Matthew Albert
    Yes swapped it with a older card [PCIE], but same problem, IDK if the card i tested with will work with This apple.
  • Hilton Bristol Aug 04, 2010
    You say you use an older card but that will not give result unless you sure the card was good and if it is compatible with you mac PC, you need to use a Graphic card/video card which is design for Apple PC.
    You can look at this video explain everything about the card and how to put it in the computer.
    http://www.youtube.com/watch?v=HmBzlAXuz...
  • 281 Answers
Yes swapped it with a older card, but same problem, IDK if the card i tested with will work with a apple
Testimonial: "ty"
    President:
  • 3,278 Answers
Hello.
From Apple Support:
In July 2008, NVIDIA publicly acknowledged a higher than normal failure rate for some of their graphics processors due to a packaging defect. At that same time, NVIDIA assured Apple that Mac computers with these graphics processors were not affected. However, after an Apple-led investigation, Apple has determined that some MacBook Pro computers with the NVIDIA GeForce 8600M GT graphics processor may be affected. If the NVIDIA graphics processor in your MacBook Pro has failed, or fails within four years of the original date of purchase, a repair will be done free of charge, even if your MacBook Pro is out of warranty.
If you have the NVIDIA GeForce 8600M GT graphics processor, contact an Apple Store or your nearest Apple Contact Center.
Hope this helps.
  • NinaE Aug 04, 2010
    Hello, again.
    Sorry ... I really thought I had the solution for you !!
    Have you swapped out the ATI card ?
  • Matthew Albert
Removing administrator from a 2nd hand apple macpro 2.66 dual core xeon ma356LL/A
i don't now much about macs i should think you need to format the disc
Apr 06, 2013 | Computers & Internet
Need service manual/ macpro 08 desktop
Have you looked at www.ifixit.com or www.powerbookmedic.com for repair guides?
Mar 23, 2013 | Apple MacPro 8 Core 2.66GHz Quad Core...
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
MacPro Permission
open disc utility and after you choose your hard drive click "fix permissions" let that run, reboot and try again.
Dec 10, 2011 | Apple MacBook Pro Laptop Computer with...
Hi i have a macpro 13" not turn on ,the pwr adapter light its dim, i replace the adapter and continue not turn on . its not a new mac and was working few hour ago
If the power supply is dim it indicates a motherboard problem and is loading the charger down. The only option is to have a computer tech who is familiar with Apple Notebooks to check it out with an estimate.
Jan 07, 2011 | Apple MacBook Pro Laptop Computer with...
MacPro 8-core fails to startup. No power.
If nothing is happening, then you probably have a bad power supply or you have bad connections between your power supply and motherboard. You can take the cover off and make sure that everything is plugged in well. Make sure to touch the side of the case to dispel all static electricity before you touch any of the components. If the machine fans turn on and then it refuses to boot, you might have a bad hard drive or a motherboard issue. If you hear any beeps at startup, you can look those up online because every beep configuration is a clue to something wrong with the machine.
Jul 19, 2010 | Apple MacPro 8 Core 2.66GHz Quad Core...
Hi, I have forgotten password for Macpro apple. how could i get involve?
Hi and welcome to FixYa,
I cant find Macpro, but Macbook pro from Apple.
- if this is the one, then:
In a word 'no', you need the disk, then it is very easy.
If you have lost your disks, Apple will replace them for a small cost, less than the price of a retail version of Tiger.
You could also take it to your local Apple Store and ask if they will help...they shouldn't charge you anything !
regards
/Teis -> dont forget to vote
Dec 07, 2008 | Apple MacBook Pro Laptop Computer with...
When turning on my macbook pro
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Mar 03, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
