Question about Motorola Mobility H670 Wireless Headset
H670 bluetooth not working
My blackberry 8800 shows me connected. When I call, I can only hear out of the phone and the h670 starts out with solid blue and turns blinking red. What do I do?
Try adding headset, select blue T. device the properties, services and check headset and apply
Posted on Jul 11, 2008
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
How do i pair motorola h670 with blackberry torch
Please kindly follow the detailed solution provided below;
STEP 1 Put on the motorola h670 by pressing and holding the switch button for 5secs,afterwards you will hear a click followed by a blinking of blue lights,by now the headset is in pairing mode.
STEP 2 Activate the bluetooth radio on your blackberry torch,by clicking on the menu>set up>bluetooth>search.
STEP 3. After searching,your torch will find the motorola h670 in the list of found devices.click on it,afterwards a message will display saying "pairing complete".
By now your blackberry torch has been successfully paired with your motorola h670 headset and you are good to go.
Take care!
Dec 05, 2010 | RIM BlackBerry Torch Cell Phone
Cannot connect my blackberry tour to my mercedes bluetooth program. its is asking for a passkey which i do not have
BLACKBERRY PRODUCT
BlackBerry Bold 9700 ...............$350
BlackBerry Storm2 9520 ............$320
BlackBerry Curve 8520...............$300
Blackberry Tour 9630 ................$250
Blackberry Curve 8900...............$230
Blackberry Storm 9530 ..............$230
Blackberry Storm 9500 ..............$250
Blackberry Pearl Flip 8220 .........$200
Blackberry Bold 9000.................$240
Blackberry Pearl 8110................$230
Blackberry Pearl 8120.................$215
Blackberry Curve 8320...............$180
Blackberry 8830 World Edition ...$180
Blackberry 8100 Pearl ...............$180
Blackberry 8300 Curve .............$170
Blackberry 8800 .......................$165
Blackberry 8820 ...................... $160
Contact: Mr. Randy Barnett
Email: isell.seitz@gmail.com
Email: isellfast198@yahoo.com
Nov 10, 2009 | RIM BlackBerry? Tour 9630 Smartphone
No caller id on Blackberry 8800 when using bluetooth headset
yes it will happen when u connect with your Bluetooth you have to use your Bluetooth only no u can see anything on your phone
May 16, 2017 | Verizon Communications BlackBerry Pearl...
Folks can't hear me when I talk on my blackberry bold but I can hear them. This as only started since I connected with my bluetooth device. Any suggestions? The phone is only 3 months old
This could be caused by a software error in which the phone still thinks the bluetooth is still connected and is still being used as a microphone you can try a couple things here: 1. go to your bluetooth device list on your phone and delete the device 2. try to connect and then disconnect the bluetooth device and see if that returns everything back to normal 3. when you are calling or get called select the blackberry menu which is basically the blackberry icon on the keypad and go and find the option activate headset or something close to that which should activate the speaker on phone which you use for your ear.
I hope this helps,
Kyle
Jul 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
The blurtooth is not going into pairing mode. I was using this bluetooth (motorola h670) with another phone and I just changed the phone.
you will have to reset your bluetooth device first and then start pairing process with the new mobile.
thx
Feb 25, 2009 | Motorola Mobility H670 Headset
Blackberry 8800 headphones aren't working
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Jun 06, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
Need help
you will have to install blackberry desktop manager in order to route enough sufficient power to your blackberry device. you can download that software from the CD rom that came with your phone or by going to the following link:
http://na.blackberry.com/eng/services/desktop/
as soon as you download that software go to options, connection settings and change the connection type from NONE to USB PIN: ^^^^^^^ and it will charge just fine! :)
Apr 20, 2008 | RIM BlackBerry 8800
Motorola h670 bluetooth
Manual Says 0000 but it does'nt work for me. Any other ideas anyone?
Mar 14, 2008 | Motorola Mobility H670 Headset
Motorola Mobility H670 Wireless Headset Logo
130 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
