Question about Technics SA-DX1050 Receiver
When i turn on the receiver it immediately gives me a ¨F70¨ error message on the display
    Problem Solver:
  • 4 Answers
This is a problem related to the out put section, try disconnecting alls the speakers from the receiver and turning on the unit. If your unit comes on then mostly any of your speaker or associated cabling is getting shorted . If the same problem persists then usually the amplifier needs service attention, refer to a qualified engineer.
Posted on Nov 14, 2010
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
AV CONTROL RECEIVER SA_HE7 F70
F70 error checking fixed contacts fuses.
Oct 04, 2013 | Panasonic SA-HE7 Receiver
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
Panasonic SA-he75, displays an F70 error.
The F70 error is a code for "protect". See the link below for a general explanation of protect mode. Specifically for your unit, the output amplifier IC has failed. This can be replaced, but the parts cost will be in the $100 range. Please update this if you have further questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 08, 2010 | Panasonic SA-HE75 Receiver
F70 problem
Look up "Panasonic F70 error" on Google and you will find plenty of discussion about this problem.
The F70 is a blown fuse error. It looks like you can can the fuse yourself, if so inclined, otherwise send it to a service agent.
Aug 03, 2008 | Panasonic SA-HE70 Receiver
Panasonic SA-HE100 5.1 system error code F70
According to the operating instructions, you must take it to a repair facility. There are no troubleshooting suggestions for this problem in the manual.
Dec 15, 2007 | Panasonic SA-HE100 Receiver
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
F70 Error on SH-AC300
unit has a blown internal fuse. replace it with exact type of fuse and see what happens. if it blows again, it will need to be returned to a service agent
Sep 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX1050 Receiver Logo
493 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
