Question about BYTECC VUP-215 Skype IP Phone
Tengo un telefono Bytecc VoIP USB Phone Pro VUP-215: cuando hago o contesto una llamada; la voz proviene de la tarjeta de sonido del PC en lugar del teléfono USB, la otra persona no me escucha. cuando le doy Abrir la ventana principal de Skype, hago clic en Herramienta-> Opciones->Configurar Entrada y salida de audio; no me aparece SkyWin USB Phone, solo "microfono Audio device" en Entrada de Audio y "Speaker Audio Device" en salida. Ya baje el Driver que aparece en la pagna de Bytecc (http://byteccusa.com/driver.htm) y aun asi no funciona. cabe acotar que mi pc tiene instalado el window seven. El telefono no recibe ni emite audio. las demas funciones si funcionan.
5 Suggested Answers
  • 7 Answers
SOURCE: ME-940 usb enclosure not reconized
This behavior occurs if you map a network drive to the first available drive letter after the drive letters for the local volumes and CD-ROM drives. When you install a new device or volume, Mount Manager, which assigns drive letters to volumes, does not recognize the mapped network drive and assigns the next available drive letter to the new device or volume. This causes a collision with the existing mapped network drive. To prevent this issue from occurring, when you map a network drive, assign the highest available drive letter to the mapped network drive. To work around this issue if the new volume appears in Disk Management, specify a different drive letter for the new device or volume. To do this, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Disk Management. 3. In the list of drives in the right pane, right-click the new drive and then click Change Drive Letter and Path(s). 4. Click Change, and in the drop-down box, select a drive letter for the new drive that is not assigned to a mapped network drive. 5. Click OK, and then click OK again.
Posted on Jul 09, 2007
SOURCE: Bytecc BT-300 USB 2.0 drive mate problem
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Posted on Feb 22, 2010
issken
  • 1472 Answers
SOURCE: IDE hard drive in Bytecc ME-535U2 enclosure not recognized by OS
smc4
There is a couple of things that could be going on. The first thing to check is that the drive did not get bumped off its drive letter by another device. If that is the case you just the to assign it a new one. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
The other issue is the drive may have gotten disconnected improperly. I had the same problem with one of my drive on my XP system as well. It partly has something to do with the USB controller to my understanding. Alot of times if you plug it into another computer it will detect it and ask to run a scan to repair the drive. After this you should be able to access the drive on your XP system again. Note I have the best resolutes when I plugged the drive into my Vista system. So I would recommend trying to plug it into a Windows Vista or 7 computer to attempt the repair.
Let me know if you have any more problems or questions.
Issken
Posted on Feb 23, 2010
bronk50
  • 27725 Answers
SOURCE: i have windows 7 and
you might be installing the driver through the right process
click start right click on computer select properties device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Posted on Jul 25, 2011
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Aug 30, 2012 | Computers & Internet
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
En mi pc no tengo sonido ocurre que borre algunos programas de internet por que mi pc estaba lenta cuando pongo en win amp sale una advterncia Bad direct sound driver cod 88780078 y en otras aplicaciones...
Usted no dijo que tarjeta de sonido usted tiene, pero si esto es un problema de chofer, usted puede encontrar un chofer bueno con un programa llamado Drivermax. Descargue aquel programa e instálelo, y usted puede usarlo para localizar a dos (2) choferes por día gratis. (para más que que usted tiene que pagar) Si usted me dice (el 1) Sistema operativo, (y 2) su tarjeta de sonido puedo tratar de encontrar un archivo de chofer para usted.
Jun 14, 2010 | Computers & Internet
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Yosi
Tiene que identificar la targeta de sonido.
Si usted tiene un laptop o bien un PC de marca conocida, vuelva a preguntar aqui Solve Your Problems , incluyendo detalles sobre el modelo.
Si el PC es sin marca o asemblado, necesitera aceder a la motherboard, o a la tarjeta de sonido para leer el numero imprimido en cima de la tarjeta.
Despues poste todos los detalles sobre el numero aqui.
Una alternativa es comprar una nueva tarjeta de sonido, esto tapoco saldria muy caro:
Creative Labs CT4830 Sound Card $7
Creative Labs Sound Blaster Sound Card $9.99
Creative Sound Blaster Audigy SE$24 to $33
Oct 12, 2008 | Computers & Internet
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
ALBERTO BRAVO
la tarjeta de sonido tiene un numero de serie y marca..busca los controladores en la web bajalos al destop o un dico e instalalos de ahi..el archivo es un archivo comprimido al descomprimirse se intalara en el disco duro. instala el driver de las propiedades del harware.
Aug 13, 2008 | Computers & Internet
Panasonic KX-T7730X
Please how do I make conference call?
Jul 21, 2008 | Panasonic KX-T7730 Corded Phone
Cesar
para bajar el driver tendrías que proveer el modelo exacto de la placa de sonido, y si está integrada en el motherboard, proveer el modelo exacto del motherboard... los puedes encontrar en la caja de los mismos y si no la tienes, abre el gabinete y buscalo impreso en el mother o en la placa de sonido si esta es externa. Normalmente los modelos de motherboards están impresos con letras blancas y son similares a esto P4V8X-MX y en el caso de las placas de sonido SoundBlaster Live Value 5.1 o algo por el estilo, dependiendo la marca...
obten esa informacion y regresa para enviarte a donde bajar los drivers.
Mar 21, 2008 | Computers & Internet
BYTECC VUP-215 Skype IP Phone Logo
233 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
richie46
Martin Clarke
Martin Clarke
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
