Question about Dell Computers & Internet
Dell laptop monitor black. Works with external monitor. Looking to find out how to check the hinge wireing or internal connections
  • 11,361 Answers
Please read here for your model, http://www.insidemylaptop.com/
more likely to have bad backlight inverter board, worst case will be the lamp assembly.
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 04, 2010
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
Laptop all whit screen
Dell Inspiron 1420 Notebook PC?
The white screen can be fixed. How?
Connect a VGA monitor to the laptop. Connect to the VGA port on the right rear. Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
By default the display should show on the external VGA monitor.
No?
Press, and hold the Fn key down, and at the same time tap the F8 key ONCE.
Still no?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F8 key.
No display on the external VGA monitor, means you have a bad graphics chipset. Replace motherboard.
Display does show on the external VGA monitor, means you have a problem with;
1) Video Cable
or
2) Screen Inverter
or
3) LCD screen
Video Cable:
The Display Panel Cable (Video Cable for Dell), connects to the motherboard by the left Hinge.
Goes under the left Hinge, and up into the Display Assembly.
It then connects to the Screen Inverter, and to the back of the Display Panel. (LCD screen for Dell)
From normal opening, and closing of the laptop, the Display Panel Cable may become pinched in the left Hinge.
This can cause;
A) The connection at the motherboard to come loose
B) The connection at the back of the Display Panel to come loose
C) Stretch the wires inside the Display Panel Cable's sheath, and damage the wires. (Break)
If you are lucky just the connection at the motherboard, and/or connection at the back of the Display panel, may have come loose.
Diagnoses is to NOT just look at the connections, but physically push the connectors of the Display Panel Cable, into the connector at the motherboard, AND back of the Display Panel.
Visually inspect the Display Panel Cable's sheath. Do you see any outward appearance of damage? This means the tiny wires inside may be damaged.
Replace the Display Panel Cable.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Keyboard Cover.
Unfasten the Keyboard, LEAVING the Keyboard Cable ATTACHED to the motherboard. Roll the Keyboard over, and lay it upside down on the Palm Rest Cover,
http://support.dell.com/support/edocs/systems/ins1420/en/SM/display.htm#wp1129771
[ NOTE*
Two Philips head screws at top of Keyboard. After removing, lift the top of the Keyboard up a little, slide it a LITTLE towards the Display Panel.
DO NOT lift it straight up at first.
There are 3 plastic tabs on the bottom of the Keyboard, that slide into the Palm Rest Cover. If you pick it straight up you will break those tabs off ]
In Removing the Display Assembly, note where number 1 points to.
This is the Display Panel Cable's connection, TO the motherboard.
Note where number 2 points to. Those cables going to the Mini-Card Antenna, HAVE to be reconnected, right back to the SAME terminals on the Mini-Card. Make a mark on the cables, and matching marks on the Mini-Card.
Use the instructions in Removing the Display Bezel.
Use the instructions in Removing the Display Panel.
View the last illustration in Removing the Display Panel.
Note how the Display Panel Cable attaches to the Display Panel, and Screen Inverter
Number 2 points to the connection at the back of the Display Panel
Number 6 points to the connection to the Screen Inverter
The Black connector that is not numbered at the bottom, is the motherboard connector of the Display Panel Cable.
This is a better view of the screen Inverter,
http://www.ebay.com/itm/Dell-Inspiron-1420-1421-LCD-Inverter-Backlight-Combo-/370274752470
Display Panel Cable checks out? Look at the screen Inverter. This small circuit board is located at the bottom of the Display Panel, and behind the Display Bezel. Closer look at link listed above.
Is the cable coming from the Display Panel Cable, plugged in tightly to it?
Does the screen Inverter look damaged?
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Jun 09, 2012 | Dell Inspiron 1420 Laptop
During startup screen doesn't show anything, but a grayish white. backlight working, cables ok, and seated correctly, no visible damage to inverter boards. one small black wire leading to built-in webcam...
connect an external PC monitor to the slot on laptop...
you will know where is the issue....
if the monitor works then there is an issue on the display of laptop....else some other issue....
Nov 01, 2010 | Dell XPS M1330 Notebook
The monitor does`nt work, but the computer still works,how can I get a Dell monitor to work with the T41 notebook. I have them connected,but the monitor stays black
This may be a defect in the graphics card, since the external monitor (is it properly connected to the VGA-connector and is the power on?) should be recognized automatically and display instead of the internal monitor. The behaviour of the laptop in case an external monitor is connected can sometimes be controlled via the BIOS, which is impossibile to do if the internal monitor or the graphics card doesn't work. I'm afraid that, if you can't reset the BIOS yourself, this may be a case for the repair service.
- Marinus
Sep 29, 2010 | IBM ThinkPad T41 Notebook
My Dell Vostro 1500 laptop screen just blacked out. The computer is still running and when connected to an external monitor, it works. Any suggestion on what to check?
your problem is easy to fix the cable from your lcd to your motherboard is disconnected,here is what you will have to do first remove the battery,the ac cable then if you are strong enough use your fingers to pry away the hinge cover off from right to left, and then remove it from the computer.You will see below a biege cable which is the conector to your motherboard unplugged.Plug it in and carefully replace the hinge the battery turn it on and you should see the dell logo.
Good Luck
Aug 26, 2009 | Dell Vostro 1500 Notebook
Laptop has black screen, woks when hooked up to external monitor
just re-connect LCD connector properly its a loose connections. check also inverter maybe loose.
May 29, 2009 | Dell Inspiron XPS M140 Notebook
Black LCD Monitor Dell Inspiron 8600
Since the external monitor displays and dim image on the laptop's LCD screen then the fault is the LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 04, 2009 | Dell E228WFP LCD Monitor
Black screen
Hook it up to an external monitor, if everything works properly, then check the screen connections, one may have worked loose. Screens will go out without warning, so, if the connections are good and it works with the external it may be the screen. If the external doesn't work then it's an issue with the video card.
Jul 10, 2008 | Dell Inspiron 5160 Notebook
Inspiron 1150 screen is black
It is one of three things usually Bad cable at the hinge, Failed inverter board, or failed backlight. Probably inverter. Not to difficult to repair. Check cable first because it is inexpensive and easy. Check the inverter and replace if needed . Sometimes you can buy one used cheap with a bad motherboard and swap the top.
Jan 19, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
351 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
