Question about Skull Candy Lowrider Headphones
Can i fix the wires to my headphones, i cut through them
  • Skull Candy Master
  • 5,508 Answers
See my tip on dealing with dodgy cable/plugs on headphones.
Posted on Aug 07, 2010
3 Suggested Answers
  • 274 Answers
SOURCE: cut wires
Per the KOSS website your KSC 75 stereophone is covered under the Lifetime Warranty Policy. To have your product serviced, please send the stereophone along with $6.00 each ($7.00 Canadian) shipping and handling to the appropriate address for your location. In the United States: Koss Corporation 4129 N. Port Washington Ave. Milwaukee, WI 53212 1-800-USA-KOSS email: customersupport@koss.com In Canada call: 1-800-USA-KOSS email: customersupport@koss.com Outside US and Canada: Contact Koss S.A. for the distributor/repair centre nearest you: ++41-91-641.61.20 email: customersupport-intl@koss.com
Posted on Jul 19, 2007
Grubhead
  • 5508 Answers
SOURCE: I cut the wire while
Contact the maker of the headphones they might let you have a replacement if you explain why you damaged them.
Posted on Jul 29, 2011
No sound in left headphone
Yes, sure. But it's a bit difficult, because you have to find the broken piece of it. Look for cuts in the wire. If you can see it, you can cut the protecting piece over the wire open or off and connect your wires again. Melt them together and it should work.
Jan 02, 2014 | Wesc Bongo Headphones
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
My headphone wire was cut into two parts how do I fix it
Just strip the insulation back to reveal the wires, there should be 3 wires, one for the left headphone, one for the right headphone and a shield wire.
join the wires that have the same colors (solder each wire together) wrap each wire with insulation tape so they do not short against each other and then bind the whole lot together.
You headphones should work again.
Apr 04, 2012 | Dell Computers & Internet
I cut the wire while trying to cut open the intense packaging to the headphone. How can I fix the wire?
Jul 22, 2011 | Skull Candy Audio Players & Recorders
My left headphone stopped working after a year or so. How can i fix this?
The copper wires inside the cable have broken. Since you don't know where the break occurred all you can do is to open the left headphone, remove the speaker, cut a piece of the cord and resolder it to the speaker. Test it, if it's fixed just put the headphone back together. If not, cut another piece. If you must cut more than a third of the cable to get it working then it's dead, just buy a new pair.
Jun 30, 2010 | Sony Bud Style Headphones
The right earphone on my headphones stopped making noise yesterday. There is no volume coming out of it at all and right now i am listening out of my left ear only. I was able to fix the problem by pulling...
if you are techy or have a knowldge in connecting wire, then you can give a try to fix the right portion of your headphones. There was just a wire inside of your earphone which have been cut. For some instance maybe you had pull your headphones thats why the wire inside has been cut. If you can't repair then that's the time you'll need to buy.
May 26, 2010 | Sony Clip-On Style Stereo Headphones
Loose connection in Bose headphones
Cut the ******** and replace it with a new one. You will need to solder the wires on to the new one. Keep the old one, cut it open and it will tell you which wires go to which terminal.
Jan 06, 2010 | Bose QuietComfort 2 Consumer Headphones
Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Sep 19, 2009 | Bose TRIPORT® Headphones
Wiring
You may be able to take the back of the speaker can off the speaker plate on that side to rewire the headphones. You have to carefully remove the earpad and look for screws holding them together. Make note of which color wire connects to what at the solder connection. Cut your cord shorter and cut back the insulation. Test for continuity from the plug to the newly exposed wires with a volt ohm meter. You should be able to get the old piece of cord out of the grommet in the headphones to insert the working cord. Hope this helps.
Jul 04, 2009 | Bose on-ear TriPort Headphones
Skull Candy Lowrider Headphones Logo
117 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
