Making a crackling noise from rear speaker - Televison & Video
  • 6,993 Answers
the problem should be from the speaker. Its either the speaker has burst or gotten some holes.
Take care.
Posted on Aug 05, 2010
  • snags362 Aug 05, 2010
    I had figured that out already, I want to know if you can fix it
  • Walesarumi
    Walesarumi Aug 05, 2010
    It either you seal the speaker hole that is causing the crackling sound or change the speaker.
    Use a glue or gum to seal up the hole on the speaker.
    Or replace the speaker if you want it to sound well again. Open the unit, unscrew the screws holding the speaker, bring out the speaker, replace it with another speaker and couple it back.
    Take care.
Chevy blazer wiring diagram
to test for speaker wires, take a 9volt battery and touch the ends and when you here the speaker make a crackling noise, then you found your speaker. mark left rear or so on.
May 20, 2014 | 2002 Chevrolet Blazer
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
Nakamichi mini speaker has crackling noise as soon it is switched on
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Audio Players & Recorders
I tried to install an aftermarket 6 1/2" speaker
possible reasons:
Impedance mismatch
wiring is grounding out on frame/metal
speaker isn't OEM and is slightly "pinched" thus causing cone distortion
One of these three will be your issue.
Also, you may remove the speaker and leave it hanging with the wires attached. Knowing that no wiring is shorted and nothing is disturbing the cone, try running your stereo. Same crackling problem? It may be an impedance issue or you reversed the polarity on your speaker.
It will require some work but the solution is there if it was working before.
Apr 12, 2011 | 2003 Chevrolet Impala
Crackling noise in the rear right speakers often...
Try connecting another speaker that is known to work to the Rear right connector, and if the crackling noise still appears, it is a problem with your wiring, receiver speaker terminal, receiver internal board, or the device connecting to the amplifier or the wiring from that device to the amp. Usually this is a wiring problem, or faulty crossover.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 09, 2011 | Denon Audio Players & Recorders
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Left side crackling noise Blown channel?
Would check your balance settings. Make sure your not balanced more to left than right. Next i would try to swap over one of the speakers from right side to left to see if it crackles. If not replace left side speakers.
May 19, 2009 | JVC KS-FX200 Cassette Player
My speakers just started making crackling noises.
try and se if there is dust build up and blow it off
Feb 06, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Apr 23, 2007 | JVC RX-558V
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
