Question about Garden
Spa continuously runs - Garden
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Unplug it
Posted on Aug 04, 2010
Power to control panel is off and pump continues to run ?
you need a new 3 hp relay trace wires from filter button red and black wire go to the relay
Apr 12, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Sundance 605 Series spa. Recently had the motor replaced, but now the motor runs continually. Installer said I need a new board. Is there anything else that could cause this?
When a spa runs continually it can be a bad board but we would have you replace the Temp Sensor first. If the spa is not heating it could be the pressure switch is not working or it could be the Temp Sensor or the High Limit sensor.
Check the topside panel to see if the heat indicator light is on. If it is NOT on then your pressure switch needs to be changed.
If the Heat indicator light IS on then you probably just need a Sensor.
It is always possible that the heater relay on the circuit board is bad.
Rod
US Parts Center
888-521-6183
Mar 31, 2013 | Pool & Spa
AGS error code
check gas pressure if ok then see if runs 7 sec if shuts off then check flame sensor if blower doesn't start check safety circuit
Nov 24, 2012 | Jandy Lx Pool & Spa Heater - Electronic...
6521 REV GGG code
check 4 pin red plug inside to see if shorted wire ends or cut wire to controller
Apr 29, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
