Question about Samsung Heating & Cooling
I have a Samsung window air conditioner model #AW25ECB8. The compressor only runs 3-5 mintues and the fan runs about 55-57 mintues in a hour. The room is more than big enough to keep running right. It acts almost like energy saver switch is on but it is not.
SOURCE: My air conditioner doesn't blow out any air.
If this is a central air unit & you\'re talking about the fan on the outide of the house the problem may be that you are only getting 110 volts to the system side of the contactor. If you have the tools & know how you can check this yourself. If not, time to call a repairman.
Posted on Jun 01, 2007
  • 30 Answers
SOURCE: Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Posted on Feb 01, 2009
  • 659 Answers
SOURCE: how to disable the energy saver of the amana ptac
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Posted on Mar 21, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
daddyo742001
  • 70 Answers
SOURCE: This goldstar air conditioner model is WG2405RY7
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Air conditioner turns on in the inside but not the outside
The click you heard was an internal overload in the compressor. Your a/c shouldn't cycle on and off every few minutes. The short cycling causes the compressor to over heat. You need to figure out why you have such a short run time with your a/c. Check the thermostat.
Jun 16, 2009 | Goodman CKL24AR24 Air Conditioner
Compresor turn off every 3 mintue
ya the compressor might be switch off by the thermostat . the thermostat setting might be not cool or # 2. Or thermostat need replacement if you had set it to the cooler side.
Jun 16, 2009 | LG BG8000ER Air Conditioner
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
A/C Samsung spilt ( working fine then after 8 hours gives warm air)
It sounds to me like your fan cycling switch is sticking while the unit is cycling off (fans). When this happens your condenser does not have the ability to remove the heat from the refrigerant which in turn causes the compressor to load heavy. This creates a very high pressure condition on the high side. When this happens go outside and see if the condenser fans are running.
Hope this helps You
please rate me
Jul 18, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
