Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
The Sony wag a is on & working but it is making a popping noise and it had a smell. Turned it off and had no more problems but concerned it might be getting ready to go out. I thought it might have gotten a bug in it or something. What do u think?
  • 10,594 Answers
Of course popping noise and smell are not good symptoms for tv and it needs visual check.
What kind of smell you get from tv? is it some thing burning or getting heated?
Can you take off its back cover and see its main circuit board to find out what part is giving smell. Let me know its number written on circuit board to see its position in schematics. Is it Sony KV-27HS420 tv or any other model?
Thanks.
Posted on Aug 04, 2010
Was watching 11 year old rear-projection TV & suddenly there was a pop, & the TV turned off. I tried to turn it back on, but no response but a clicking, and then i smelled a hot, ozone-y smell.
No , you should not be concern about the fire because you unplugged the T.V .Firstly you have to see that your product is in Warrantee .and if its in the warrantee then you have to call the customer services and ecplain them the situation then they will send a guy to see what the actual problem is and most probably if its in warrantee then they are gonna replace it ...
Feb 18, 2016 | Zenith Televison & Video
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
Speaker noise
Could be a capacitor on the board or something entirely different, if it starts to smell funny turn it off quick.
Oct 03, 2009 | Televison & Video
My W3201C 32" LCD TV made a loud popping noise when I turned it off. Now it will not turn on. No power. No LED light.
That would be your transformer popping and dieing. Usually the popping is followed by a burning smell which is a good indicator that the part is unrecoverable. The cost of the part is variable based on the make and model TV and is usually not too labor intensive to replace. If not under warranty, let the repair gut know that you know what the problem is. Then, ask them to quote the cost of the replacement part and part number. Then ask them to quote you their hourly rate and get a time estimate. Then, google the part number and see if the cost is reasonable.
May 02, 2009 | Televison & Video
Grindin noise on My 97 Dodge Caravan when heat is turned on .
yes,could be something in there rubbing against fan cage.
Nov 15, 2008 | 1997 Dodge Caravan
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
