Question about ViewSonic VE150 15" LCD Monitor
Hi, I have an old Viewsonic ViewPanel VE150 Monitor that has never given me a problem. Now when I turn it on I get a black screen that says no sync. The power button comes on greeen then turns orange. Is it time to get another monitor? Or can this one be fixed?
  • 732 Answers
Jafaba8, Your VE150 could be 7 -8 years old!! Time to get a new wide screen unit and maybe do research into a DIY refurbishment of the VE150 to keep as a spare unit? Check the date of manufacture on rear of unit??? Let us technicians know what you will do. Bye for now.
12fixlouie
Posted on Aug 04, 2010
My monitor screen stays on at start up for a few seconds, then turn completley white. Ive tried restarting, shutting down, changing monitors. Whats wrong?
If it happens with multiple monitors, maybe it's not the monitor that's the problem: your graphics card might be dead, and that's why it turns white.
Oct 16, 2013 | Epson Viewsonic ViewPanel VE150M Monitor
What does it mean when i turn my laptop on the screen is white.
I can't tell you what it means but it happened to my laptop this morning.
After reading tons of "solutions" nothing worked. Finally, I turned it off, went grocery shopping for a couple of hours and when I came home and turned it back on and it seems to be fine.
I am, however, going to make a recovery disk like the computer has been suggesting since I got it.
Dec 16, 2010 | Epson Viewsonic ViewPanel VE150M Monitor
I need to know how to brightness more I see a little but not bright enough How the buttons work? What can I do to fix it?
Hi, from the "Desktop Screen; (right click) to open the "Properties" listings, select, and open. Once the next window "open," find the "Display" category, and open. Select the (Highest Color settings). You can also "Adjust the Resolution aswell, if that will give you a better visual display. Once you are finished making the "adjustments," click on the "Apply, and OK button before exiting. I hope it helps! " "Rating the solution if appreciated, just click on the "Thumbs Up"
Apr 30, 2010 | ViewSonic VE150 15" LCD Monitor
I have a ViewSonic VE150 15 in. Flat Panel LCD Monitor and it doesn't work good with windows XP I' can't adjust the monitor more than 800 x 640. Do I need a controller?
Native resolution for this monitor is 1024 x 768 @60Hz.
It sounds more like you do not have the correct Video card driver for your PC. Please verify and post back.
Apr 27, 2010 | ViewSonic VE150 (White) 15 in. Flat Panel...
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other...
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Dec 09, 2009 | ViewSonic VA902b 19" Monitor
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Severe noise on monitor when viewing white area
Although I still have the problem to a slight extent (very slight wavering of the vertical lines going from dark to light or white) reducing the contrast from 100% to 80% seemed to do the trick. Although this monitor is on the way out, it has lasted about 7-8 years now, at least it will keep going for a while.
Dec 29, 2008 | ViewSonic VE150 15" LCD Monitor
ViewSonic VE150 15" LCD Monitor Logo
240 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
