Question about Dishwashers
Whisper wash 1 will not start.No lights.Breaker is fine.Seems like a internal breaker has flipped
    Champion:
  • 274 Answers
Is the door secured
Posted on Aug 04, 2010
Was working fine. Tried a few days later to dry a load and the starter wouldn't turn load on.
First. Check voltage if its a electric type flip breaker all the way off than back on sometimes breaker flips halfway. Then check for a thermal overload near blower housing usually long and white if it fails motor won't run
Jun 12, 2015 | Dryers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
I have a KitchenAid Whisper Quiet Dishwasher. Has been working fine. Circuit breaker seem to be working but control board is now not lighting up and buttons do not respond. Seems like no power to...
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Aug 07, 2010 | KitchenAid Dishwashers
Seems like no power going to knob
check power at oulet blowdryer other apliance if no power reset breaker at panel to reset push breaker oppisite direction of other breakers than flip back in line with others good luck
Apr 14, 2010 | Maytag HAV2557 Top Load Washer
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but...
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 16, 2008 | Dryers
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
