Question about Toshiba Computers & Internet
Toshiba Satellite 1405-S171 Laptop from friend had the bios password locking me out of even booting the thing up, so i unplugged the cmos battery for 5 minets then plugged it back in, now i can see the green led light on but it will not power UP???????? can the battery stop it from booting? thanks
5 Suggested Answers
Paul319581
  • 101 Answers
SOURCE: laptop will not turn on,its
hi take your battery out for 1/2 hour and then try turning it on and clean the terminals of the battery..
hope this will work !!
Posted on Mar 10, 2008
  • 320 Answers
SOURCE: I need to know
Try removing the battery inside for the bios, and the jumper for clearing the CMOS. or try flashing the bios. I am sorry, because its very dificult to get the inside pictures of the laptop. Otherwise Download the latest bios and install it in your laptop. Hopefully it should work. Thank you
Posted on Sep 10, 2008
RPFinney
  • 385 Answers
SOURCE: Boot Problems
PXE means it will only boot while connected to the network,
You need to change the bois From network boot to Hard drive boot.
The system doesn't see a hard drive inside,
it thinks it is booting from the network only,
it boots to a server like this.
It is called a dumb terminal
Richard.
Posted on Apr 26, 2009
jell587
  • 447 Answers
SOURCE: BIOS PASSWORD REMOVAL on a toshiba satellite L45 S7409
This link describes the bios password reset for various Toshiba models (it's at the top of the results list), hopefully this will help you take care of your problem.
I would also think that Toshiba support would be able to assist you with this should you call them.
Posted on Apr 28, 2009
Lost password...No help on internet so far for this model
There's only two ways to reset the CMOS battery on this laptop.One is to short out two solder points on the motherboard, which works on this model, as per this guide:
http://findpassword.net/reset-toshiba-satellite-bios-password/
The other is to contact Toshiba for support. They'll be able to help so long as you can prove ownership.
Oct 21, 2012 | Toshiba Satellite L15-S104 Notebook
Password unloking
The simplest way to remove BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
If that doesn't work,you'll need a bios/cmos password recovery tool from http://www.biospasswordrecovery.com
Jun 04, 2012 | Computers & Internet
Password bios toshiba 4000cdt
If you've forgotten your BIOS password, or if someone has changed the password on your Toshiba laptop without your permission, then there are a couple things that you can do to reset the password and access your computer.
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password
Use a Backdoor Password
· If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Dec 06, 2010 | Toshiba Satellite 4000CDT Notebook
Trying to get past a bios password on my toshiba laptop given by a friend
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 22, 2010 | Toshiba Satellite L305-S5908 Notebook
I have a Satellite L45-S7423 Toshiba Laptop the Vista Windows Passwords stopped working. Then after shutting down and powering back up the Bios password is no longer working. The password that I used in...
It's completely possible your CMOS (small BIOS battery) inside the laptop has died. If you are able to disassemble a laptop yourself, go here:
http:www.irisvista.com/tech/
You'll need to remove the CMOS and reassemble.
If not, try to find a friend who can help you download "Hiren's Boot CD" which has tools for resetiing BIOS and other Passwords. Be careful what you do. Study blogs about whatever steps you intend to take and be patient.
Jul 12, 2010 | Toshiba Satellite L45-S7423 Notebook
I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
My friend asked me to fix his Toshiba Satellite 4090 xdvd laptop but it has a BIOS password. What do I need to do?
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Anyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
And Thanks.
Mar 29, 2010 | Toshiba Satellite 4090XDVD Notebook
I can't inter my toshiba 1405-s171 sytem cause someone have change my bios pastwords.who can help me to bypass the password and inter the system?
goto the toshiba website and they have instructions on how to do it.
But i must say if only the bios password is set, that will not stop you from booting the machine and using it. Only from entering the BIOS.
Dec 12, 2009 | Computers & Internet
Toshiba satellite laptop 1405-S151 HDDDPassword lock
'flash your bios' Google "How to flash Toshiba Laptop Bios" and you should get your answer.
Genenerly it's just a start up hoding a button down (on the rear of your computer).
Chur.
Sep 20, 2009 | Computers & Internet
Forgot Bios Password
unplug cmos battery then plug it back in make sure laptop is unplugged fist
Mar 30, 2009 | Toshiba Satellite A205-S5879 Laptop
Computers & Internet Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
