Question about Microsoft Xbox 360 Console
Will an old xbox 360 hdd work on the new xbox 360 with kinect?
    Problem Solver:
  • 11 Answers
More than likely. It wouldn't hurt to try, but don't shove the HDD onto the 360 too hard.
Posted on Aug 04, 2010
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
Kinectic requires update
You must update. Xbox requires it for proper functioning in the xbox kinect system. This enables the xbox to recognize your kinect camera and adds more features. So you not updating it wont let it work. Its the way Xbox companies makes their money.
Mar 01, 2013 | Microsoft Kinect Sensor for XBOX 360
X box kinect not working with older x box
Microsoft wont allow xbox360 accessories to be compatible with its old xbox model. Microsoft makes money this way. so when you buy the new stuff, most of the time you always have to buy the other stuff that is just as new. the xbox360 OS (Operating System) is different from the old Xbox OS. Thats also why Xbox360 cant play the original Xbox games. This way Microsoft can keep heading in the direction they are aiming for. Its like they say, "you cant teach an old dog new tricks."
Jan 04, 2013 | Microsoft Kinect Sensor for XBOX 360
Can i put a kinnect on a old xbox.. have it got to have a certain gb to play it let me no asap ... thank you for ur time
I don't think you can play the Kinect on an old Xbox 360, since the new Xbox comes with it. I'm not completely sure on this matter, but there is no possible way the Kinect can hurt your Xbox 360 since it is just hardware and external.
Nov 08, 2011 | Microsoft Xbox 360 Console
How to connect the xbox kincet
If your Kinect only has one cord coming off of it, that should go into the back of your Xbox where there is a color coded slot (orange).
Feb 28, 2011 | Microsoft Xbox 360 Console
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
Got a new xbox 360 and kinect, have to change my tv settings to play the games i have but then get a very different picture with very dull colours
Ah, this happened to me when i got a 360S. You have an old 360, no? And you used the HDTV conmponent? Go to the console settings, and fool around with the display a bit. You'll find what you want. Just make sure you're using the OLD 360 cord or an HDMI cord; the new ones are **** and only designed to work with extremely old TVs.
Jan 30, 2011 | Microsoft Xbox 360 Console
I.m trying to play a kinect game and the kinect tuner gives me this error code (coooooc2)
Hi Chris
Kindly specify if you have a "slim" version of the Xbox 360 or the older one?
The error code you have specified here seems to triggering due to a hardware issue of your Kinect device.
If you have a older version of Xbox 360 which requires you to use a separate power supply for Xbox 360 try these steps
  1. Turn off the console.
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
Post that re-calibrate your Kinect tuner and check if it's working else you may have to get your Kinect device replaced from Microsoft
Jan 02, 2011 | Microsoft Xbox 360 Console
Does a bluetooth earpiece work for a xbox 360 kinect
No a bluetooth headset will not work with the Kinect. The Kinect has a mic built in to the unit to pick up sound from the entire room.
Thank you for using FixYa!
Dec 30, 2010 | Microsoft Kinect Sensor for XBOX 360
Trying to connect kinect.... its saying that it has insufficient power
Hi Eddie,
Try with different USB ports if you are using old XBOX and getting message as " insufficient power". It seems to be a adapter issue why don't you visit store and exchange the XBOX 360 Kinect device.
Thank you for using Fixya.
Xbox 360 kinect Games List
Dec 25, 2010 | Microsoft Kinect Sensor for XBOX 360
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
