Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
    Champion:
  • 274 Answers
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Posted on Aug 04, 2010
Why does samsung dishwashers stink?
numerous possible reasons, are you using it as a waste disposal unit, doing regular services washes, washing at the right temperature, cleaning the filter often enough, using the right detergent?
Sep 18, 2014 | Samsung Dishwashers
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
Dishwasher really holds smells from soiled foods. Can I put bleach in the dispenser periodically?
First check your main draining system. the entire gas escapes through your dish washer.
Clean the wash chamber with water. Do not try bleach as it may spoil the other parts. If still prefer to use, dilute and use.
For some time use a bucket of 10 to 15 liter and drain the dish washer out let. If the smell not noticed, it is eminating from the main drain system.
May 17, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Drain water smells, dishes dont get clean
at home depot they sell a product called affresh it cleans the inside of your dishwasher from stagnant water smells also check around the area of your chopper sometimes as chopper gets dulled food can build up in that area they also sell an affresh type for washermachines this is a great product for both types of units
Apr 30, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Smells bad
I have a very bad smell in my elite kenmore diswasher. We have had it for a year now. I have been smelling this now for several weeks and I didn't know where the smell was coming from until this morning when I pulled the door down to unload my dishes.
Jul 14, 2008 | Hotpoint 24 in. HDA3700G Built-in...
Bad smell
smell is not the fault of the dishwasher but your waste disposal unit - they stink!
it may be awkward, but arrange your drain so that there is a water barrier. better still. install a standpipe for the drain, again with a water barrier
Jul 09, 2008 | Bosch SHY56A02 / SHY56A06 Built-in...
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
674 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
