Question about Microsoft Xbox 360 Console
Hard drive wont spin. wont do anything. Two red lights come on when I cut it on.
  • Anonymous Apr 30, 2008
    the three red lights come on all the time
Well, 2 red lights mean OVERHEATED. Leave it off for a long time. It could take from days to weeks.
Posted on Apr 30, 2008
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
When i cut on my machine a black screen comes on sayin cannot boot insert cd and press enter
Could be your hard drive. Make sure all connections are good. You should have a 2 little lights on the front of system case, one is your hard drive activity light, it should be red. See when you turn it on if it blinks. Take the side of the case and listen if the hard drive is spinning when you start the computer up.
Nov 02, 2010 | Computers & Internet
My lacie hard drive is not spinning up. the light
if still in warrenty return to reseller for replacement but if outta warrenty open it up and try the hard drive in a pc and see if it works ok if it does u just need a replacement external caddy which can be found quite cheaply on most auction websites ;)
Mar 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Doesn't spin & Power light flashes red to green
This situation indicates a problem with the built-in self tests. Most likely a power supply failure. I don't believe it is economically feasible to replace the power supply. If it is still under warranty, I'd go through the procedure to get it repaired/replaced. Otherwise, you'll need to replace the unit.
Dec 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Wont boot or make noise but lights are on
remove it from the case and put it straight into your computer using a spare power plug and cable. to see if you are doing it right check one of the other hard drives in the tower switch on and see if there is any diffrents if not then i am sorry to tell you it is caput
May 26, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Working fine until psu packed in, replaced psu, begins power up
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Nov 11, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Red ring of death
It means "general hardware failure", so it could be any number of things. Its like a check engine light except when it comes on , it means something doesnt work. The only way to fix it is to send it off to xbox. Call 18004MYXBOX and they will send you a prepaid shipping label and a box and will get it back to you within a few weeks. Your xbox should be covered under microsoft's warranty so it shouldnt cost you anything. Removing the hard drive wont fix anything because the hard drive isnt needed for the xbox to operate, so if it failed the xbox would be fine but wouldnt be able to retrieve the data off it.
Oct 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
