Question about Electrical Supplies
I have a UST Model GG 1200 portable generator that I manage to get AC side working and need figure out if wiring for the bridge rectifier is right to get the DC side working. I have not been able to find wiring diagram to match colorcoded wiring with right connection on rectifier.
  • 905 Answers
SOURCE: I have a UST GG5500 portable generator and it will
Check your circuit breakers to see if they are tripped or damaged. Then take a look in the end of alternator / generator at the field windings. Check for damage to the brushes, as well as the diode for continuity in 1 direction only. Look for damaged capacitor regulator. Replace as needed.
Posted on Jun 12, 2010
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
mamicheddy
  • 79 Answers
SOURCE: DOES ANYONE KNOW ALLGENERATOR WINDING RESISTANCES ?
5 Ohms at the rotor.
Disconnect all the stator wires and measure each one to ground, it should read opened.
Before disconnecting wires, mark which are hot and which are neutral. Measure between the hot neutral wires and some should read at least 0.5 ohms. You should have T1 and T2 reading 0.5 and T3 and T4 reading 0.5. T1 and T3 should read opened, T1 to T4 should read opened. Also, T2 to T3 should be opened and T2 to T4 opened.
Posted on May 07, 2009
  • 225 Answers
SOURCE: Same Problem, diodes fell out of bridge rectifier assembly
pulling to many amps,diodes could not handle amps so they failed.unit should have kicked its breaker before the diodes burned out.most units have their own breaker to protect the system.I would replace the control board first see how unit reacts,probly fine,if not the you go to next step.
Posted on Jun 27, 2009
What spark plug is supposed to be in the UST 1200 1200 watt 79.5 CC generator
Pssst! We sell all the parts and spares for UST Generators on our website.
http://www.generatorguru.com/ust/
Need more advice? We have Generator Engineers happy to assist. Contact us, we are always happy to help!
http://www.generatorguru.com/ask-the-guru/
Regards
The Generator Guru Team
May 02, 2016 | Electrical Supplies
Wiring rectifier correctly?
You are discussing a bridge rectifier, the + connector is directly opposite the negative connector, the remaining two connection points are the AC side of the rectifier + AC
AC -
Apr 05, 2015 | Kipor Generator Kge2400 - 2400 Watts
Need wiring diagram to figure trickle charger out
Check the stator for AC output to the charge rectifier, if present stator ok, then check DC on DC side of rectifier if not present change the rectifier, ssuming all fuses have been tested
Nov 08, 2013 | Generac Electrical Supplies
Replace a rectifier on an old honda CB?
Thanks for the video!I would expect you to have gotten a detailed instruction sheet, unless maybe this is not a correct replacement part.
The distributor should be able to help you I would think. You may consider returning it if they won't or if you find out it's not the right part for you.
I did a non-OEM replacement & upgrade on a 1972 Honda CB350K3, and I used a full-wave bridge rectifier that I bought at my local Radio Shack.
You can get one like the NTE53016 (200V 40A) for under $5 via Radio Shack here.
You would ideally need to refer to the wiring diagram in your bike's service manual to be sure you get it connected correctly.
GENERALLY, but not always, positive is red, and negative is black.
One easy way to find ground is by measuring between the wire under test and the frame or negative lead of the battery.
You may have to cut wires, and either solder it in directly or attach new connectors.
Any full-wave bridge rectifier has two AC inputs, which are interchangeable with each other. They go to your generator's output.
And you will have a positive output and a negative output, usually at opposite corners from each other.
Here is a schematic for a bridge rectifier:
The bridge will be marked, and typically the positive and negative are on opposite corners, and the other two corners are the AC inputs:
Let us know if you need more help.
Dec 11, 2012 | Motorcycles
Please tell me How to change my oil in my ust gg 2300 generator
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing...
Aug 17, 2011 | UST GG2300 Portable Gas Powered Generator
Generator is not converting over from 110 to 12 volts, why not?Need a wiring diagram for the convertor box also.
You did not mention your model number, however most generators do not have the 12v charging option. Those that do like yours generally use a seperate winding producing about 14volts ac which is passed thru a full wave bridge rectifier. This rectifier us usually mounted inside the panel usually against metal to absorb heat (gets hot while in use). Look for (about one inch square) rectifier and test with meter. Replacement can be of the Radio Shack variety. Good Luck
Aug 30, 2010 | Electrical Supplies
Hi I have an eagle power generator (E65DRE) and it will not generate power. All the coils and components are alright. Do I have to (excite) the generator after it has been sitting for a while? Has any one...
Yes, that's exactly the issue. You should run it once a month to avoid this. Generators can't sit for a while or they will loose the charge that excites the coils for producing power
Sep 07, 2009 | Eagle 10000 W Portable Generator
Electrical Supplies Logo
333 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
