Question about Craftsman 24 Hp 48" Deck Yard Tractor
I am trying to replace a belt on the deck mower
  • 760 Answers
If it's a craftsman. Go to www.searspartsdirect.com and put in your exact model number (which you didn't list) then when you get to the parts listing, look on the right hand side of the page and see if there is a link to manuals for your model , if so click on that. The manual should show you pictures of your belt.
Posted on Aug 04, 2010
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
    Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
    May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Diagram on how to replace belt on deck 48
    This is an older model, but the routing might be similar.
    Apr 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
    I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
    did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
    Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    I am trying to replace my mower deck belt. I
    got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
    Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
    Craftsman 24 Hp 48" Deck Yard Tractor Logo
    94 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
