Question about Refrigerators
I own a Kenmore Coldspot 106.71182101 and the refrigerator is now warm while the freezer is perfectly cold and holding it's temp. What can I do about the refrigeratornot being cold?
I have Kenmore model 106.71182101 with the same problem; cold freezer, warm fridge. The fan in freezer is not working. I tried to spin fan blades manually with a small stick but they would not rotate. I haven't defrosted freezer - is it likely the blades are frozen or do I have a defective fan? thx
Posted on Aug 04, 2012
    Problem Solver:
  • 6 Answers
I disagree with freetek.
We have the coldspot 106.569.86601 and this same issue happened. The issue can simply be the need to defrost the whole refrigerator. Our freezer was working fine and the fridge was warm (4 years old).
We unplugged the unit and let it completely defrost for 12 hours (overnight). It takes about this long for everything to defrost, even if it may seem as though its warm in the freezer the inside fan may not be thawed yet. This is also a good time to clean it out and disinfect it. Then plug it in and it should reach satisfactory temp by 4 hours. If it is not working at this point, it is probably a compressor/sensor issue.
Doing the above worked perfectly for us. :) Good luck!
Posted on Aug 12, 2010
  • Refrigerators Master
  • 5,568 Answers
A common problem; the fan which should circulate some of the cooled air into the fridge is not running. You can verify this while the compressor is running by wetting your fingers and holding them near the vents in the back of the refrigerator. If you cannot detect any air flow, the fan is dead.
Go to Sears parts website and enter your model number. Especially since it is Kenmore, it should bring up a line-drawing and parts list for your model.
Sears Parts Direct
You can then decide whether it is accessible enough for a DIY replacement or if you would rather call a service company to replace it for you. Check with your local BBB to pick a reliable service company.
Posted on Aug 04, 2010
Kenmore coldspot 106
What is your model number?
Oct 09, 2013 | Refrigerators
A side by side kenmore coldspot the freeze is getting cold the refrigator side is very warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot not keeping cold. Ice in freezer
What are your temp controls set to? If the controls are set to the max setting and it won't reach temp, you could have a broad range of problems ranging from bad door gaskets, to bad temp controls, to a low refrigerant charge, to possible a failing mechanical part such as a fan motor or compressor.
Jan 08, 2010 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Feb 27, 2009 | Kenmore Refrigerators
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
846 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
