Question about Whirlpool Kitchen Ranges
I bought a used whirlpool electric range model #RF265LXTQ and would like to find a manuel for it on line. Could you please help me? Thank You.
fridgetech
  • 473 Answers
SOURCE: Magic Chef electric range model # 3888VRA
Sounds like the oven control needs to be replaced.
Posted on Oct 06, 2007
  • 1314 Answers
SOURCE: whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Posted on Dec 31, 2007
ranger25
  • 72 Answers
SOURCE: my electric glass top stove won't heat up?
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, or it could be the infinite switch. You will have to check resistance across the leads that correspond to each pinout. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Our Whirlpool electric range shows 5 Ab
There is nothing wrong with your range. The code you are seeing on your display is actually "SAB". It means your range has been set on "Sabbath Mode" which is used by some religions to disable the stove to honor the sabbath. It will remain disabled for up 72 hours unless you turn it off. The procedures to clear this mode differ between manufacturers, so you need to refer to the operating instructions in your Owner's Manual to see how to turn this feature on/off. You cannot clear this by unplugging it, either. If you can't find your owner's manual, you can go to managemyhome.com and type in your MODEL NUMBER under the "Manuals" link. They provide owner and installation manuals that you can view or download for FREE.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 11, 2009
protek480
  • 1723 Answers
SOURCE: WHIRLPOOL INSTRUCTION MANUAL AND KNOBS
Here you go:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196276.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 02, 2009
Good evening. I have a Whirlpool freestanding electric range GFE461LV that I bought in 2009 and for the first time I will install it. This is because I am from Brazil and since 2009 we were expecting our...
It is 220 V with a neutral conductor. If you are installing it in the United States, local electrical codes may require using a 4-wire cord (two wires for the 220 Volt connection, the neutral and the cabinet ground); otherwise you can use the neutral for grounding with a 3-wire cord. The cord and two-pole circuit breaker in your electrical service panel should be rated for 50 Amperes.
You can download complete installation instructions from Whirlpool. You can also find the Owner's manual and other documentation at the Whirlpool site.
Jun 20, 2011 | Whirlpool GFE461LV Electric Range
Surface light on
Hello, Thank You for using FixYa. I will be helping you today.The light is controlled by a sensor on the element for that light. depending on your model number you may have to replace the whole element.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Whirlpool Electric Range
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
My oven is not working. the temp led light shows F-1. What is this.
Hello, Thank You for using FixYa. I will be helping you today.Whirlpool F1 is a failed control(clock) I would of given the part number but you only gave half the model number.
Jun 12, 2011 | Whirlpool GY396 Electric Kitchen Range
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool electric range model #RF378PXGQ. Ten
the owner manuel may have a the fault code chart but if you tell me the fault code i might beable to help
Jan 27, 2010 | Ovens
Care manuel for whirlpool electric self cleaning range
Go here and find your range. once you find click on it. go to literature to get your manual.
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Good Luck and Please Rate
Jan 09, 2009 | Home
Whirlpool regulator
Hello arizonascrat
Welcome
You said You just bought a whirlpool gas stove, but it is set up for natural gas and you need it to be for propane gas. How do you do this? Do you have to purchase anything, if so where? Whirlpool GR 465 LXLS THANKS, in advance, Norma
They make an LP conversion kit What you are asking and it should cost only about $20 dollars.
One Model # is, 8576846A
Now some places have it using different numbers!
Make sure to ask if this is for you range. I believe on kit fits all Whirlpool Gas products.
We have sponsors here on fixya that you can order this from.
One I believe is the repair clinic.
Thank You for using Fixya.
Huuum
Please remember to leave me a solved rating!
Oct 12, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gas Range Ignitors Not Clicking
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your oven.
Apr 06, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
57 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
