Ok i have a friedrich air conditiong model 2004 EK12J33A serial number JJAS16278 AND i dont know what kind of breaker it takes if its a 220 or a 120 can u help ?
3 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: I need to replace a
As long as it fit inside the wall , go smaller and close the hole, or slide the new unit in the old case. & sealthe loose ends . or keep callng around..
Posted on Sep 08, 2008
  • 21 Answers
SOURCE: Friedrich model 24m continually trips circuit
How new is unit? Looks like a portable. if it has a 3 prong plug, it sounds like the compressor is shorted to ground, tripping breaker. If its new, return it, if not, junk it
Posted on Aug 06, 2009
How old is my Friedrich WallMaster WS08B10 Air Conditioner
The age of your unit can be determined from the serial number. You will find this serial number on the data tag located on the inside of the unit just below the control panel. If you will call the Customer Assistance Center at Friedrich, 800-541-6645, extension 260, they will be able to assist you with the age of your unit. Hours are Monday thru Friday 7:00 am - 6:00 pm, central time.
May 05, 2012 | Friedrich WallMaster WS08B10 Air...
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
hello
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
Do not know what kind of furnace i have. The serial number is 000125926 and the model number is DLASO
ok but whats your question I dont have that kind but the model just helps give an idea of what you got
Sep 23, 2010 | Heating & Cooling
Friedrich model 24m continually trips circuit breaker. had new 220 line installed and have replaced breaker but problem continues.
Aug 05, 2009 | Friedrich P-12 Air Conditioner
My AC needs a new 220 cable
If the damage is close to the end of the cable, simply get a replacement plug end from a home repair store and put it on.
Cut the old plug off and install the new plug.
when you go to buy the cord end, take the old one with you so you get the correct configuration.
May 31, 2009 | Friedrich QuietMaster SS12L10 Air...
Want to know if 110 V or 220 V
All electric dryers built for the US are 240 VAC, and gas dryers are 120 VAC.
Jan 28, 2009 | Frigidaire FDE336RE Dryer
Heat pump doesnt turn on when calling for heat
Make sure your power source is still supplying power. Breaker box, maybe you have another too many appliances hooked up to same circuit? If that does not work, get advise from your local distributer before having a small appliance tech charge you for the issue.
Dec 05, 2008 | Friedrich YL24J35D HEAT COOL 24000 BTU 230...
I need to replace a Friedrich Model number ek12J33A-3 wall unit. Its dimensions are 26" wide by 16" in height. I am having trouble finding a comparable unit that same size. Any suggestions...
Sep 08, 2008 | Friedrich Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
