Question about Amana ABB1927DE Bottom Freezer Refrigerator
Fridge is to cold when set on 4 - Amana ABB1927DE Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
What setting should I have fridge on I doesn't feel cold enough I have it on 8c
fridge settings go from 8 hot to 1 really cold
start setting at around 4 monitor the green vegetables in the bottom draw ( crisper draw ) and adjust if they show signs of too cold ( browning or wilting of leaves
Jun 04, 2017 | Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
My Maytag Dual Pro top freezer is running too cold.
freezer should be -15 and that is about 4-5 c on the knob
fridge should be around 4-5 C which is around +3 C
frost build up is from door opened too often , for too long or bad door seals
It is more prevalent when the ambient humidity is above 50% as it is the water vapour in the air condensing on the cold surfaces
Dec 13, 2017 | Refrigerators
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Fridge not cold enough set at 8
okay if it is not cold enough you should check the frezzer temp, and then play around with the fridge that should help. I had the same problem
Aug 08, 2009 | Master Bilt Indoor Step In Cooler 70""W x...
Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
46 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
