Question about MTX Thunder 4250D Car Audio Amplifier
I have a MTX 4105D amp and it cuts in and out what could it be
  • 70 Answers
Could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
Posted on Aug 04, 2010
Testimonial: "I had the advice double checked with someone that really knows what hes talking about and it was the same answer"
Why does my MTX thunder 702x amplifier cut on and off
Check fuse on amp under hood. Also, check wire connections makes none of them are loose and move your RCA jacks around to see if you have a short.
Jan 04, 2012 | MTX X Thunder 702X Car Audio Amplifier
I got a mtx ta7801 amp every time I hook it up it says short even when no rca our speaker wires are attached any one have any clue as to whath is wrong
Im sure you have but check all the fuses and be sure ground/power is in the right spot, and check remote wire for cuts
Dec 17, 2010 | MTX Thunder TA7801 Car Audio Amplifier
How can i hook up a second battery to my MTX 4105d amp
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
Power issue
blown fuse?speakers on their way out? check the amp fuses, then the inline power fuse.
Feb 07, 2010 | MTX Thunder 81000D Car Audio Amplifier
I have 4 MTX 10s and a JL 1400D amp and it cuts off if i turn it up to bang it what do i do
How do you have the subs wired and what impedance are they? Your amp is only stable to 2ohms. If they are 4ohm drivers, 2 have to be series & 2 have to be parallel. If their 8ohm drivers, parallel is fine. If your not sure, add a comment to this post with the model numbers on your subs and I will get you the correct info needed to do it right.
Jul 10, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Not working
disconnect the subs from the amp and check to see if the amp will turn on and stay on-check the subs to see if they are blown with a different source try a pair or a single sub that you know works fine on the amp and see if it plays-this should tell you whether your amp is fried or your subs are roasted
May 19, 2009 | MTX 4002 Car Audio Amplifier
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Car amplifiers
connectors on the rca's are bad. need to be changed out
Jul 11, 2008 | MTX Car Audio & Video
Short Curcit?
the amp have an input harness? those can go bad, or maybe line level inputs are loose. If its not just a loose connection on one of the amps inputs (speaker, line, or power) leading to the circuit board( which could easily be soldered back to the corcuit board), than your looking at an integrated circuit problem- not easy to fix.
Feb 27, 2008 | MTX TC2002 Car Audio Amplifier
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder 4250D Car Audio Amplifier Logo
100 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
